Yep, i have a MAF error.
What I’ve tried:
1. I’ve tried to clean the MAF sensor, didn’t help.
2. Tried to give the connecter some electrical connector spray, didn’t help.
3. Tried to switch between MAF 1 and 2 (don’t really know what is what but I switched them), didn’t help.
4. A friend that previously had worked at Audi insisted that I backtracked on my latest JHM tune (the error happened shortly after an update), didn’t help (and I didn’t expect that!).
So I guess that I’m down to wires.
The error is in engine module 2, but which of the two MAFs is it? Like physically. (drivers side?).
As you guys can see in the log, the MAF issue gives errors in a couple of other modules so no ESP and no adaptive cruise control.
Don’t mind that it states that it’s an V12 it’s not.
VCDS readout:
Monday,09,August,2021,10:14:17:28839
VCDS – Windows Based VAG/VAS Emulator Running on Windows 8 x64
VCDS Version: 21.3.0.0 (x64)
Data version: 20210226 DS325.0
VIN: WAUZZZ4F0-------- License Plate:
Mileage: 242220km-150508mi Repair Order:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 11 31 13 15 16 17 18 19 1E 36
37 42 46 47 4F 52 53 55 56 57 61 62 65 67 6D 72 76 77
VIN: WAUZZZ4F0-------- Mileage: 242220km-150508miles
02-Auto Trans – Status: Malfunction 0010
03-ABS Brakes – Status: Malfunction 0010
06-Seat Mem. Pass – Status: OK 0000
07-Control Head – Status: OK 0000
0F-Digital Radio – Status: OK 0000
13-Auto Dist. Reg – Status: Malfunction 0010
15-Airbags – Status: OK 0000
18-Aux. Heat – Status: OK 0000
1E-Media Player 2 – Status: OK 0000
25-Immobilizer – Status: OK 0000
55-Headlight Range – Status: OK 0000
56-Radio – Status: OK 0000
57-TV Tuner – Status: OK 0000
61-Battery Regul. – Status: OK 0000
65-Tire Pressure – Status: OK 0000
6D-Trunk Elect. – Status: OK 0000
76-Park Assist – Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No SW: 4F1 910 552 C HW: 4F1 907 552
Component: 5.2L V12/5V FSI ™0060
Revision: 59H09— Serial number:
Coding: 010D0003190F0260
Shop #: WSC 13622 410 403014
VCID: 244DE145E7AB58AB87-8070
3 Faults Found:
004105 - Mass Air Flow Sensor 1/2
P1009 - 004 - Implausible Signal from Load Calculation
Freeze Frame:
Fault Status: 01100100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 242224 km
Time Indication: 0
Date: 2021.08.09
Time: 09:58:41
Freeze Frame:
RPM: 1248 /min
Load: 27.8 %
Speed: 9.0 km/h
Temperature: 27.0∞C
Temperature: 27.0∞C
Absolute Pres.: 1010.0 mbar
Voltage: 13.081 V
000257 - Mass Air Flow Sensor (G70)
P0101 - 004 - Implausible Signal
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 242225 km
Time Indication: 0
Date: 2021.08.09
Time: 10:03:28
Freeze Frame:
RPM: 1566 /min
Load: 73.3 %
Speed: 32.0 km/h
Temperature: 59.0∞C
Temperature: 24.0∞C
Voltage: 13.335 V
P1923 - 008 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 242226 km
Time Indication: 0
Date: 2021.08.09
Time: 10:07:54
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 77.0∞C
Temperature: 29.0∞C
Voltage: 12.954 V
Readiness: 0010 1101
Part No SW: 4F2 910 156 M HW: 09E 927 156 C
Component: AG6 09E 5,2 FSI RdW 0020
Revision: --H01— Serial number: 0093839
Coding: 0000001
VCID: 2F671E69BE6DEBF36A-807A
1 Fault Found:
006231 - Load Signal
P1857 - 001 - Error Message from ECU
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 242225 km
Time Indication: 0
Date: 2021.08.09
Time: 10:03:15
Freeze Frame:
RPM: 1280 /min
RPM: 1248 /min
RPM: 800 /min
(no units): 35.0
(no units): 20.0
Temperature: 35.0∞C
T.B. Angle: 3.1∞
Address 03: ABS Brakes Labels: 4F0-910-517.clb
Coding: 0020920
Shop #: WSC 02325 785 00200
VCID: 31631811A859FD037C-8064
1 Fault Found:
18265 - Load Signal
P1857 - 000 - Error Message from ECU
Freeze Frame:
Fault Status: 01100000
Fault Priority: 3
Fault Frequency: 2
Reset counter: 143
Mileage: 242225 km
Time Indication: 0
Date: 2021.08.09
Time: 10:03:12
Freeze Frame:
Hex Value: 0x1B00
Hex Value: 0x4006
Hex Value: 0x0028
Hex Value: 0x01AA
Hex Value: 0x00FF
Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb
Part No SW: 4F0 910 852 A HW: 4F0 905 852 C
Component: FBSAUDIC6 ELVSG H01 0030
Revision: 31050601 Serial number: 10601200548099
Coding: 0000131
Shop #: WSC 02323 785 00200
Subsystem 1 - Part No: 4F0 910 131 E
Component: FBSAUDIC6 EZS H45 0080
Subsystem 2 - Part No: 4F0 910 220 D
Component: FBSAUDIC6 IDG H01 0040
No fault code found.
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory BFS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0070752
Shop #: WSC 02334 785 00200
VCID: 61C3A851B8390D83AC-8034
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F0 910 732 M HW: 4E0 035 729 A
Component: Interfacebox H43 3460
Revision: 00000000 Serial number: 351JO067526106
Coding: 0011003
Shop #: WSC 30058 123 12345
VCID: 2D5B0461B46199E358-8078
Subsystem 1 - Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H02 0060
Subsystem 2 - Serial number: 00000000546690
Subsystem 3 - Serial number: 0110.10.060000000100011434ˇ
Subsystem 4 - Serial number: 011434ˇ
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 HW: 4F1 820 043 AC
Component: KLIMABETAETIGUNGH20 0170
Revision: 00000031 Serial number: 00000000311284
Coding: 0530698
VCID: 5BBF9AB99A552753F6-800E
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 J HW: 4F0 907 279 A
Component: ILM Fahrer H15 0240
Revision: 00000000 Serial number: 4F0907279
Coding: 0115122
Shop #: WSC 02335 785 00200
VCID: 30651D15A353F40B73-8064
Subsystem 1 - Part No: 4F1 910 113 C Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0210
Coding: 00064784
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00478288
Shop #: WSC 02335
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBF8202414
Shop #: WSC 00000 000 00000
VCID: 1C3DD9A5DFDB606B3F-8048
Address 0F: Digital Radio Labels: None
Part No SW: 4E0 910 563 C HW: 4E0 035 563
Component: DAB-Tuner H41 0830
Revision: 00000001 Serial number: KE1276U7400049
Coding: 0000001
1 Fault Found:
000267 - Mass Air Flow Sensor (G246)
P010B - 004 - Implausible Signal
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 242225 km
Time Indication: 0
Date: 2021.08.09
Time: 10:03:28
Freeze Frame:
RPM: 1569 /min
Load: 73.3 %
Speed: 32.0 km/h
Temperature: 59.0∞C
Temperature: 24.0∞C
Voltage: 13.081 V
Address 13: Auto Dist. Reg Labels: 4F0-910-561.lbl
Part No SW: 4F0 910 561 B HW: 4F0 907 561 A
Component: ABSTANDSREGELUNGH05 0060
Revision: -------- Serial number: 00000000000000
Coding: 0041168
VCID: 2241E75DFDBF569BF5-8076
1 Fault Found:
01316 - ABS Control Module
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 182
Mileage: 242224 km
Time Indication: 0
Date: 2021.08.09
Time: 07:55:58
Freeze Frame:
Temperature: 32.0∞C
Voltage: 11.90 V
Bin. Bits: 01000
Hex Value: 0x2513
Hex Value: 0x0007
Speed: 0.0 km/h
Lateral Accel.: 0.00 m/s^2
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
Component: 43 AIRBAG AUDI8RH29 0280
Revision: 08H29000 Serial number: 0037LD0H18B
Coding: 0013363
VCID: 2953F071808985C3B4-807C
Subsystem 1 - Serial number: 6332CSME1240034FX
Subsystem 2 - Serial number: 6342CSME12400341K
Subsystem 3 - Serial number: 6352QSME11221F436
Subsystem 4 - Serial number: 6362QSME140C2477F
Subsystem 5 - Serial number: 63734SME5D192101X
Subsystem 6 - Serial number: 63834SME142C4D6DE
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 A HW: 4F0 953 549 C
Component: J0527 0410
Revision: 00H03000 Serial number: 90025062590016
Coding: 0012352
VCID: 2757F649969DB3B3A2-8072
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H07 0090
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 930 C HW: 4F0 920 931 H
Component: KOMBIINSTR. M73 H18 0120
Revision: 00600000 Serial number: 5H456XU96
Coding: 2257543
Shop #: WSC 12345 123 12345
VCID: 234FE259E2A55F93FE-8076
Address 18: Aux. Heat Labels: None
Part No SW: 4F0 910 105 G HW: 4F0 265 081 J
Component: Heizgeraet H08 0060
Revision: C Serial number: 09011480
Coding: 0000111
Shop #: WSC 20853 000 1048576
VCID: 2143E851F8B94D83EC-8074
Address 19: CAN Gateway Labels:. 4F0-910-468.clb
Part No SW: 4F0 910 468 A HW: 4F0 907 468 E
Component: Gateway H11 0070
Revision: 11 Serial number: 12009065228026
Coding: EEFEF3DF3B7D06
Shop #: WSC 22829 142 84435
Address 1E: Media Player 2 (R192) Labels:. 4E0-035-785.lbl
Part No SW: 4E0 035 785 HW: 4E0 035 785
Component: SG ext.Player H09 0170
Revision: 0
VCID: 65CBBC416C1161A350-8030
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H04 0050
Coding: 0066658
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 P HW: 4E0 919 887 D
Component: MNS ECE H48 1060
Revision: 00000000 Serial number: 364J0067597275
Shop #: WSC 00493 128 21413
VCID: 3B7F3A397A150753D6-806E
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0120
Revision: 00000000 Serial number: âs
Coding: 0001774
Shop #: WSC 02327 785 00200
VCID: 2C5D09658F7B90EB4F-8078
Part No SW: 4F0 910 289 B HW: 4F0 907 289 B
Component: Komfortgeraet H22 0170
Revision: 01700022 Serial number: 01021141370000
Coding: 3549941
Subsystem 2 - Part No: 4F0 910 177
Component: Innenraumueberw.H01 0020
1 Fault Found:
01134 - Alarm Horn (H12)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 254
Reset counter: 143
Mileage: 176572 km
Time Indication: 0
Date: 2018.11.09
Time: 20:41:49
Address 47: Sound System Labels: 4F0-910-223-BO.lbl
Part No SW: 4F0 910 223 J HW: 4F0 035 223 G
Component: DSP-High C6 H09 0240
Revision: PROD_01 Serial number: 00000000017806
Coding: 0000126
VCID: 254BFC41EC91A1A390-8070
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000298259
Coding: 0011114
VCID: 5EB993AD8947327B91-800A
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0120
Revision: 00-00000
Coding: 0001774
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 B HW: 4F0 907 801 A
Component: EPB CB4C0060 H04 0060
Revision: --H04—
Coding: 0008021
Shop #: WSC 02324 785 00200
VCID: 1F47EEA9CECD7B73DA-804A
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Coding: 0000016
Subsystem 1 - Part No: 4F0 941 329 B
Component: AFS-Modul links H02 0020
Subsystem 2 - Part No: 4F0 941 329 B
Component: AFS-Modul rechtsH02 0020
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 Q HW: 4F0 035 541 H
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 394J2067688408
Coding: 0000001
VCID: 2E59036DB967E2FB61-807A
Address 57: TV Tuner Labels: None
Part No SW: 4E0 910 148 B HW: 4E0 919 148
Component: R0078 TVhybridTuner 0360
Revision: R0H05000 Serial number: 76300700578201
Coding: 0000301
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: J0644 BEM H12 0590
Revision: 00000000 Serial number: 00000000125886
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 2610070339
Coding: 344630393135313035442056413032363130303730333339
Shop #: WSC 12345 384 00290
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0050
Coding: 0001070
Address 65: Tire Pressure Labels: 4F0-910-273-HI.lbl
Part No SW: 4F0 910 273 C HW: 4F0 907 273 A
Component: Reifendruck 3 H05 0100
Revision: 00050100 Serial number: 00000700018935
Coding: 0222725
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 R HW: 4E0 035 753 A
Component: SDS 3500 DE H45 0630
Revision: 00000000 Serial number: 00000609280517
Shop #: WSC 12336 024 394758
VCID: 356B2C015C31D12320-8060
Address 6D: Trunk Elect. Labels: 4L0-910-945.clb
Part No SW: 4F9 910 591 HW: 4F9 827 851 E
Component: ValeoHeckdeckel H21 0280
Revision: --H21001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: 6CDDC9654FFB50EB0F-8038
Subsystem 1 - Part No: 4F9 910 592
Subsystem 2 - Serial number: E5030100B
Subsystem 3 - Serial number: RD24.09.06–H21001001A0303ˇ
Subsystem 4 - Serial number: 1A0303ˇ
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0050
Coding: 0001070
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 G HW: 4F0 919 283 G
Component: Parkhilfe 8-Kan H12 0060
Revision: 00H12000 Serial number: 06330626801817
Coding: 0201116
Shop #: WSC 131071 1023 2097151
VCID: 2855F5759B83BCCBAB-807C
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4E0 910 336 M HW: 4E0 862 335
Component: Handyvorb2 H20 1130
Revision: 00000000 Serial number: 00000005161937
Coding: 0010900
End-------------------------(Elapsed Time: 03:34)--------------------------
