S6 carbon cleaned. Now if
Just got done doing an extensive carbon cleaning. I just got the car a little over a month ago and went ahead and did the cleaning myself. Added intake spacers while I was in there.
Here are my issues now. I’m getting random check engine lights when I do a cold start. It idles like it’s misfiring but when I rev the engine a little it seem fine. Its also randomly getting a high idle. It will go up to about 2k rpm and just sit there. It cruises down the interstate just fine. Once it was warmed up and I was on the interstate it drove fine. No check engine lights on the drive home from work. All I did was clean the carbon out of the valves and off the ports in the manifold where it meets the head.
I know I probably have some intake flaps broken and hope to fix that at some point. Prior to taking things apart and cleaning the engine ran fine. Idled perfectly and drove very smoothly. I can’t figure out what I could have messed up while I had it apart. If anything I was expecting it to run better. The transmission is not got the bad lurching when i’m in traffic and it downshifts. Although I think some of the lurching may be due to the high idle.
Any suggestions?
