S6 Rattle - timing chain going?
I’m not having much luck with my S6. I’ve just sorted (fingers crossed) a load of issues with oil leaks and the crankcase breather system. My mechanic has pointed out that the rattle on start-up that lasts about 30 seconds may be my timing chain.
The rattle does sound to come from the engine bay - as you look to the front of the car its on the right underneath the windscreen wipers. I’ve researched it but have a couple of questions.
Is this something I need to do sooner rather than later, or just deal with it if it gets worse? Since the chains rarely fail is it most likely to be a failing guide, ie easy job to sort once the engines out? I’m just trying to prepare myself for what I have in store…
