S6 V10 Transmission Fluid change - DIY? Tips?
First, Hello.
I have been lurking for a while, am pretty handy (rebuilt my '95.5 S6 engine a while ago among other car related tasks) and generally feel pretty comfortable working on vehicles. I just finished brakes/brake fluid flush, oil change and inner CV boot replace on the '08 S6 and have even tackled the dreaded pinch bolt when redoing UCA bushes. I want to change the transmission fluid, but as with everything I do, I want to gather as much information as possible before doing this.
I have been searching on this forum, other forums and google in general. I have looked at the Bentley for R&R info and read stories on other car’s fluid changes. However I cannot find a write up on changing the V10’s transmission fluid, specifically how to get the pan off the transmission without dropping the engine to remove the exhaust, which seems to be in the way.
Also, from what I have read, this is not so much a flush as it is a replace whatever drips out through the pan drain hole and when the pan is removed - which is my current dilemma.
I checked through the DIY’s on this site, read several posts about this, found some mentions about the Y Pipe being a PITA, even saw a video entitled something like “S6 V10 Transmission Fluid Change” (which shows fluid dripping out into a giant clear tub for a couple of minutes but nothing else) but no real step by steps and tips/suggestions.
So before I dive in, does anyone have any suggestions?
Thanks in advance for any advice!
Ed
