S8 Brake upgrade
I have been drooling over my Q7s fixed 6 pot front and fixed 4 pot rear brakes.
The D3 S8 has a pitiful floating single rear and 2 piston front.
Rotor diameter is somewhat large on the front, rear is meh. IMO the braking could be improved…and I also have a thing for fixed calipers.
Q7 calipers are cheap. Rear rotors-5mm larger on the S8…wonder if I can just swap the bracket and caliper over?
Front…would require an adapter I assume as I would need to use the Q7 bracket as well…
