Secondary Air Pump or SAI rebuild? remove?
I have an allroad on its way out the door, I first am replacing the valve cover gaskets, plugs, yada yada yada… Not too long ago I had the high speed whine of the SAI impeller of death shreek going on in the cold months. It stopped, which means to me it died. I bought a block off plate but may save that for one of the allroads that are staying. I remember someone talking about rebuilding theirs. Is this possible? Where can I get the parts? Any help would be appreciated.
Here is the thorn in my side:
http://www.audizine.com/gallery/data/500/20150630_122802.jpg
Remove the clips
http://www.audizine.com/gallery/data/500/medium/20150630_1228151.jpg
Notice there is an aligning tab
http://www.audizine.com/gallery/data/500/medium/20150630_122832.jpg
Pull on the housing to seperate
http://www.audizine.com/gallery/data/500/20150630_122904.jpg
This is what lies within,
http://www.audizine.com/gallery/data/500/20150630_122953.jpg
there is a nut and a bushing that has already been removed
http://www.audizine.com/gallery/data/500/20150630_123020.jpg
Remove the two screws then pry on the edges of the motor as it is snug
http://www.audizine.com/gallery/data/500/20150630_123056.jpg
Slide motor out
http://www.audizine.com/gallery/data/500/20150630_125128.jpg
Out of its home
http://www.audizine.com/gallery/data/500/20150630_125202.jpg
Here is the problem with mine
http://www.audizine.com/gallery/data/500/20150630_125906.jpg
