Hey guys,
I wanted to look into two things.
First, I’m right around 93K miles and I know I’m getting closer (if I’m not already there) to the point where I won’t be able to have a trans flush performed. I’m curious to see the results from others who have done it and which ATF they used for the flush. Right now, I’ll get the ZF lurch every now and again… it’s gotten better with the JHM ECU tune, but will still occur when not completely stopped and seems laggy when switching gears. Also, do we have any news on the JHM TCU tune being decentralized (AKA not in California or Michigan)? I’m sure that would help a lot.
Second, 30 minutes ago during my drive home I noticed a CEL flash on and off several times on the dash then disappearing (no limp mode, rough idle or any true signs of engine component failure). I can’t think of why that would be other than the SAI delete that was recently done ~1K miles ago. The shop removed the entire pump and all the components then put on the SAI delete and new gaskets. Is that the proper way to go about doing it? I’ll still probably get the car looked at again just to ensure there’s nothing crazy going on. My S6 has all new injectors, spark plugs and carbon clean ~2K miles ago.
I appreciate everyone’s input.
