Service schedule
These are the main Audi service schedule miles. With the added important updates owners have found useful at the very top
Also some good maintenance thread links to look at. Lots of interesting information
http://audirevolution.net/forum/index.php?topic=3950.msg114965#msg114965 - Its a build thread but its good tons of good stuff.
Most important. Carbon clean. - Check and inspect every 10k
FSI injectors. Pull and have inspected every 80k
5.2 V10 intake manifold. - have inspected every 20k. The 5.2 intake manifolds have a tendency to break and when they break the car will loose lots of power.
All the vac lines and hoses to the intake and top of the motor. - inspect every 15k
Oil seperator and PCV system - every 25k
Fuel filter. - 35k
Coolant. - Check and replace every 4 years. You can update to G13 it cools better then G12
Engine Oil – change oil and replace flter Audi originally said 10k. Its found closer to 5k gets better results.
Brake Fluid – replace every 2 years regardless of mileage. - This isnt done by enough people. If you road race the car you might want to inspect it each season.
Wiper Blades – check condition and replace if necessary - Check just before winter months
Wiper/Washer/Headlight Washer – check adjustment and function, add fuid if necessary
Tires and Spare – check for wear and damage, check pressure
– check for wear and damage, check pressure and renewal date of tire set (where applicable) - inspect just before the winter months.
Tires – rotate - depending on driving style. every 8k
Brake System – check for damage, leaks, pad thickness, fuid level Cooling System – check level, add if necessary - inspect every10k
Exhaust System – check for damage, leaks - Every 15k
Engine On-Board Diagnostics – check fault memory - If you have a vag com at every oil change or every 5k
Engine Compartment – check for leaks Battery – check and replace if necessary
Dust and Pollen Filter – replace 20k
Automatic Transmission and Final Drive – check for leaks every - 15k
Front Axle – check for excessive play, check dust seals on ball joints and tie rod ends - 15k
Lights – check all lights, check headlight adjustment - as needed
Drive Shaft Boots – check - 10k
Front Sunroof Drains (where applicable) – open sunroof to check front water drain and clean if necessary (U.S. only) - before winter season
Plenum Panel – remove cover to plenum panel to check water drains and clean if necessary (U.S. only) - before winter season
Doors – lubricate doors, check straps and hood latch - As needed due to use or about once a year
Spark Plugs – replace at 35,000 miles or 3 years, whichever occurs first. So very 35k or every 3 years.
Power Steering Fluid – check, add if necessary - Flush every 35k
Air Cleaner – clean housing, replace flter element 35K
RibbedV Belt andTensioner – check condition and replace if necessary 75K only:
– check condition and replace if necessary. Check tension of belt drive with manual tensioner and retension if necessary.
Clean Underbody – check for damage and leaks - Once a year
RoadTest – check braking, kick-down, steering, electrical, heating and ventilation systems, air conditioning, ASL Automatic Shift Lock and power accessories - Before each winter season
Rear Lid Hinges – inspect Vs usage about every year
lubricate Horn – 50k
check function Brake Discs – check thickness Just before each winter.
Lights – check all lights via instrument cluster. - depending on usage or once a year
Check license plate light from the rear of the vehicle - just before and after the winter months.
Interior Lights – check all interior lights, glove box illumination, control lights and MMI (if applicable) - once a year
