JHM Intermediate Kit ordered on the last day of their 10% discount.
Other parts ordered:
079103121AF upper oil pan to short block seal #3 $19.68
079103121AE lower oil pan to upper oil pan seal #2 - $19.68
079105193 X2 diamond washers for electrical camshaft adjusters - $129.60 total/$64.80 each
N91086201 X2 bolts for mechanical camshaft adjuster - $11.20 total/$5.60 each
077133287A X2 o-rings for exhaust side rocker arm shaft - $22.08 total/$11.04 each
077133287B X2 o-rings for intake side rocker arm shaft - $22.08 total/$11.04 each
N10156205 X10 bolts for electrical camshaft adjusters $11.20 total/$1.12 each
N10451409 bolt for upper left roller gear between the crank and camshaft timing chains - $0.80
079109497 X2 washers for exhaust camshaft sprocket - $39.36 total/$19.68 each
N90638402 o-ring for lower right timing chain tensioner - $0.96
N90832501 X2 oil cooler o-rings - early VIN part - $3.52 total/$1.76 each
N90956601 o-ring for oil pipe just incase I need it - $0.96
N90806302 X2 o-rings for water pump and front coolant pipe - $5.12 total/$2.56 each
N91008902 different o-ring for water pump - $2.56
077253039C X2 exhaust manifold gaskets - Elring - $8.38 total/$4.19 each
079103383BA right cylinder head gasket - Elring - $47.99
079103383BB left cylinder head gasket - Elring - $49.99
077103385D X20 cylinder head bolts - Victor Reinz - get the set of 20 for $35.99
036109675A X40 valve stem seals - Victor Reinz - $27.60 total/$0.69 each
079103161D valley pan cover gasket - Elring - $6.99
079103121AH X2 lower oil pan to upper oil pan seal #1 and front water pipe seal - CRP - $5.78 total/$2.89 each
079103121S seal for oil pump pipe to upper oil pan - OEM - $17.89
034115427B o-ring for the dipstick tube - OEM - $4.89
079115131 square seal for oil pump to upper oil pan - OEM - $7.39
079115131A o-ring for oil pump to pipe for upper oil pan - OEM - $7.39
079115131B seal for oil pump to oil pickup - OEM - $7.39
N90422301 X2 o-rings oil pipe - OEM - $13.66 total/$6.83 each
077103245B PCV valve/oil separator - OEM - $108.34
079109091B left side gasket for electrical camshaft adjuster - Elring - $4.49
079109092B right side gasket for electrical camshaft adjuster - Elring - $4.49
077198025B left side valve cover gasket set - Victor Reinz - $27.99
077198025C right side valve cover gasket set - Victor Reinz - $27.49
WHT002015 X44 bolts for camshaft bearing caps - OEM - $47.96 total/$1.09 each
079103051D front crankshaft seal - early vin part - Elring - $20.69
079115540A piston spray jet valve - OEM - $24.95
079103175C X2 oil check valves - OEM - $99.90 total/$49.95 each
059919501AS1 Engine coolant temp sensor/o-ring/C-clip kit - Febi - $5.21
079103121J upper oil pan to short block seal #1 - OEM - $8.94 @ ECStuning with limited quanity sale or I can get them from the dealership for $9.60 if they run out
079103121AA upper oil pan to short block seal #2 -OEM - $8.94 @ ECStuning with limited quanity sale or I can get them from the dealership for $9.60 if they run out
N90981001 X2 bolts for exhaust camshaft sprocket - OEM - $9.90 total/$4.95 each
