Slight steering knock or noise . . .
Hi all,
So the s6 has a slight steering knocking noise when the car is stationary.
It pretty much is when you have the wheels straight and you rotate left and right about 30degrees. The noise can be felt through the steering wheel, as a single knock each time.
I took it to my usual solid wheel and suspension shop, they cant see anything under the car. Steering linkages and all suspension bushes with no issues found.
So it’s down to a rack issue or maybe how the rack connects to the linkages etc.
Anyone had this issue in the past? As in steering rack issues?
There is no noise once the car is under way
