Hi, I’m Slow.
Seriously though, I figure I should share this here as well since my original thread is on AZ. The thread isn’t really a “build” thread but more of a progress thread and if it helps someone better understand their B6 in the future, then I’ve done my part. I’ll just post and copy the good stuff here with less BS ;D
What I had:
2001 B5 S4
https://farm8.staticflickr.com/7230/7163377148_88430dfac6_b.jpg
Mods:
APR Stage 2 Tune
2.5" Catless Techtonic Downpipes
2.5" ASP TruDual Exhaust
VAST RS4 Stage 1 Clutch/PP
Forged DV
Supporting Mods:
Samco Silicone Hoses
VAST RS4 Motor Mounts
Koni Coilovers
Febi/Bilstein CAs
What I went to:
2005 B6 S4 Avant
https://farm4.staticflickr.com/3928/15413060891_c69f1d8725_k.jpg
Mods:
JHM 93
JHM Intake Spacers
JHM Rebuilt Heads w/ HD Valves, Ti Retainers
JHM LWCP
JHM LWFW
Stage4 Clutch/PP
Fast Intentions X-Pipe (14" Resonators)
Milltek 2.5" Catless DPs
Supporting Mods:
Apikol Snub Mount
034 Street Density Motor Mounts
034 Adjustable Upper Control Arms
FCP Lowers/Endlinks
Koni/HR Sport Springs
Aesthetics:
PowerStop Slotted/Drilled Rotors
18x8.5 et35 Miro 111s
OEM European Valeo Headlights
Timeline/Event:
59xxx - Tune/Piggies/Spacers/Exhaust Install
77xxx - Piggie Removal/Downpipes Install
79xxx - VCGs/Coilpacks/Sparks/Brake Pads Refresh, LWCP Install
90xxx - Adj UCA, CA, Shock/Springs Refresh/Install
92xxx - Oil Check Valves/Fuel Filter/Fuel Pump Refresh
95xxx - Timing Guide/Tensioners/Mechanical Adjusters/Rotors/Pads Refresh, Cylinder Heads/Clutch/PP/LWFW Install
