Snow Stage 2 Meth install (aka how to spend too much money on a meth kit)
I’m not a fan of mounting nozzles in soft couplers/hoses. It seems like a lazy man’s way out to me. I question their long term reliability. If for whatever reason I need to remove the nozzle down the road, I can just screw in a plug (or weld it shut if I get my TIG welder). I went with the end tank over the piping simply because it is a nice flat surface. The thickness is comparable to my aluminum charge pipes, but I felt I could get a more secure fit by installing it on the flat end tank. I don’t know if it matters much or not, but in my head it seemed more beneficial to give the nozzle spray room to fan out vs. installing it in a 2.25" charge pipe. I figured the more it could expand right off the bat, the faster it could evaporate. This could be completely bogus though.
As expected, there is significant sloshing in the tank when you drive hard. I start to get intermittent low level signals when I’ve used about a gallon out of the 2.5 gallon tank. Not a huge deal, but I’ve got a plan to deal with it. I just bought a TIG welder, so I’m going to make a stainless meth tank complete with baffles to minimize sloshing. I’ve also considered using fuel cell foam but haven’t decided. I will probably mount the new tank outside the cubby and just behind the driver’s side rear seat. I’ll probably shoot for something in the neighborhood of 3 gallons.
Baffles work good fuel foam works best.
Thread update: I made my own meth tank out of aluminum and ditched the plastic tank. Capacity went from 2.5 gallons to 4 gallons with the new tank.
http://i10.photobucket.com/albums/a129/2fast4sanity/image_zpsdb502b02.jpg
http://i10.photobucket.com/albums/a129/2fast4sanity/image_zpsb888d073.jpg
http://i10.photobucket.com/albums/a129/2fast4sanity/image_zpse4af6042.jpg
C’mon man, you gotta make that door install a little cleaner. At least make a semi gasket around the hole. The tank and everything else is too pretty to just have the project finished like that lol.
Nice work on the rest of it though!
some small diameter heater hose with a slice in it around that edge might do the trick just to clean it up.
I wonder what would be the benefits of meth to the B7 RS4’s. Longevity of the engine, maybe?
I’m going to do something with it. I just don’t know what yet. It went in at 11pm and I didn’t have anything available to put around that edge.
Nice tight fit. Really looks like your using all the available space
Did you vent the tank?
Yessir, I drilled a 1/16" hole in the cap to vent it.
Just an update: 5 months in and there is absolutely zero signs of any corrosion inside the aluminum tank.
