And the good news is that I never ran slower than 13.XX seconds, but I also never cracked 12s (not even close). Here is some info.
Car: 2007 Audi RS4
Mileage: 34,400
Modifications: Milltek non-resonated/non-valved exhaust, Stasis MS suspension
Maintenance: Oil hasn’t been changed since like Sep of last year. I’ve probably put 3K miles on it since. Air filter hasn’t been changed in a year, probably about 6K miles on it. Fuel filter and sparkplugs have never been changed. Carbon clean has never been performed.
Weight: I don’t have the numbers handy from my corner weighting, but it is basically stock. I weigh about 175 lbs, 1/2 tank of Shell 93 octane, and a ~40lb Infinity Basslink in the trunk.
It was about 65 degrees out when I ran, somewhat humid out. I got 13 runs in within 1.5 hours, but never appeared to experience heatsoak.
Some additional info / learnings:
- Launching at between 3000 and 3200 rpm seemed to work best for me. Higher resulted in wheel hop.
- I had the traction control off (blinking) and sport mode on (yeah, I know it doesn’t make you any faster)
- I wish the RS4 had a slightly taller 3rd gear. Shifting right at the end of the 1/4 definitely slowed me down
- I missed 4th gear several times. Argh.
- I generally shifted at ~7500 rpm in gears 1 and 2…closer to 8000 in 3rd
Results:
Best run was 13.36 at 104.28 mph. Obviously not that happy, but at the same time I now have a baseline to work from. My 60 ft times were pretty consistently in the 1.9x range, so I feel like I was launching reasonably well. The mph concerns me a bit…seems low. And the ET is not all that pretty. I ran faster in my '02 ///M Coupe and '01 ///M3.
So, take a look at my timeslips and try and diagnose this for me. What should I work on? And is my mph concerning?
BTW, the reason for the baseline was that I plan on doing a CC in the next couple weeks along with some other mods (intake mani spacers, P&P manifold) and maintenance (fresh plugs, air filter, and fuel filter).
Top 2 run slips below.
