^^^That’s no joke either…the money they put into this is sickening. If I were a business advisor I’d have told them ages ago STOP!
They’re really stubborn though lol
Snow Trooper…do you know anyhting about the Vortech V3 and when intercooling will be an issue with it? Thinking of the RS4 project or the built motor supercharged car(s).
Holy shit i havent been on here in a while. Id say the main reason is internet bickering that this thread demonstrates perfectly.
Just to clarify a few things. Notorious VR is a friend of a friend (and a friend that i have not spoken to in quiet a while at that). I dont know what he gets up to on the internet but i do know my dealings with him and real life have shown him to be a stand up guy and quiet frankly i dont give a kentucky fried fuck about the internet. We spoke on facebook id guess well over a year ago.
Anyways, this build has gone on for so long that i cant even remember the details. As saki said earlieritwas running pretty much stock with a SC early in the game to see what the SC would do on a stock auto high mileage car. If i recall correctly there was also some fiddling done with e85 at one point. There have been many issues from day 1 and it has been an uphill battle. Everything from VAST holding onto my car whil i was deployed and putting the project
Back 3 month to trials and errors with what id call an engine re engineeering over a motor build. In the very early stages of the game VR and many other people recommended doing a manual swap for obvious reasons. It wsas talked about with JHM but we decided to persue the much more difficult avenue of building up and tunning the tranny. This is still a goal of jhm in the future but i elected to do a manual swap just recently in order to speed up the project. JHM will keep my auto tranny to continue work in the TCU tunning arena.
Anyways to sum up, the JHM 4.2 TT project is alive and making progress. It has been an incredibly long and frustrating process but i can assure you all that JHM has bent over backwards (as have i ) for this project. Its pretty safe to say JHM has eaten a financial shit burger on this project but we have a stuck through it to ensure one day we have a fully built properly running 4.2 tt.
Anyways, hope this clears some stuff up im going to bed.
#4 was a result of money shifting was it not? I think that’s the story we got from the tech who posted the pic of the rod in the oil pan.
#5 (me): Combination of worn/scored items. My valve guides were slightly worn allowing some oil to pass through. The main culprit was every one of my rod bearings was scored and two piston skirts were out of spec. There could be more skirts out of spec but they only measured two and then made the call to replace the block. Obviously, the combination of all of these failures resulted in significant oil consumption.
I was thinking about fitting a front mount intercooler when I get the JHM supercharger like on the B5s but the piping to the intercooler off the supercharger would require a 180 bend or so and it would be really helpful if you could spin the metal intake pipe between the throttle body and intake manifold around 180 degrees so the piping off the intercooler could go up by the coolant bottle. Of course I still have to look into it and don’t have the supercharger yet.
I wouldnt bother with an intercooler on the stg 1 set up, the blower is barely working hard at that point and the intake charge is only 20-30*F over ambient from what I’ve seen.
depends on how hard you push the turbos and how well they are matched to the motor… I believe the goal of the turbo car is monster power (with the built motor and all) so the turbos will probably be pushed pretty hard, so in that case an intercooler would be a good idea… but concievably you could aim for a lower power goal, dial back the turbos and run a low boost set up with no intercooler. As long as the compressor spends a good portion of the power band in a high efficiency island it shouldnt make a massive amount of heat.
