[SOLVED] Advice: error codes for AdvanceKey and TPMS
Relatively speaking, my 2007 S6 has been running trouble free since August. But over the summer I had an insurance claim that involved body work repair and the replacement of 1 rear tire. Ever since then, I’ve had 2 annoying issues:
  1. AdvanceKey (keyless ignition) doesn’t work
  2. the TPMS fault always comes on.
In dealing with TPMS, I replaced 2 front tires so 3 are new and 1 is new-ish. And today, an eagle-eyed tech at the tire shop spotted a rubber stem coming from the insurance replacement. He believed that there is no TPMS sensor in that tire. I spoke to my summer mechanic about it, and he insisted that Audis to not use sensors inside tires – I believe he is referring to “indirect” TPMS which may be a feature on newer Audis.
Can anyone confirm that our 2007 S6s use TPMS sensors attached to the stem before I confront my local mechanic? I’m a little stuck because he’s the only game in town.
Also, does anyone have any experience with the AdvanceKey faults before I start to swap parts?
Ignition authorization:
00180 - Access/Start Authorization Antenna, Passenger Side (R135)
00191 - Passenger's Door Handle Touch Sensor (G416)
Tire pressure monitor:
01521 - Sensor for Tire Pressure
Heater & air conditioning:
00797 - Sunlight Photo Sensor (G107)
Engine:
P1923 - Please Check DTC Memory of ECU Number 2
Engine (2):
P1573 - Left Eng. Mount Solenoid Valve, Open circuit
Parking brake:
02442 - Function lamp in control head
