Semi-update time. I pulled the oil pan off to reseal it. In the process, I had a hunch about the JHM Oil cooler bracket thing leaking so I pulled the alternator and it’s bracket off to check. Sure enough, there was a little puddle under the alternator signifying that some oil had leaked from the Oil cooler bracket. One of the AN fittings seemed a bit loose and I was able to do two full turns with a crescent wrench to tighten it. The other fitting was TIGHT. Somehow, two turns didn’t satisfy me or make me feel that safe. So I broke out the hammer and tightened that fitting about 3/4 of a turn more by hitting the crescent wrench. Needless to say, it’s tight and shouldn’t leak. Reinstalled the alternator and put sealant on the oil pan and bolted it all back up.
The front end is still off because I wanted to replace the gasket that goes from the water pipe to the block and that’s arriving in the mail tomorrow along with my Motul Oil.
This is what the oil pan hides. NEAT!!
http://i.imgur.com/GUlbrHX.jpg
Aforementioned puddle
http://i.imgur.com/s6NI3J9.jpg
Hope that’s tight enough on those fittings
http://i.imgur.com/nh3hxIN.jpg
All back together (kind of). Starting to finish that intake piping. Just need like 4 more inches of pipe and a coupler and it should be done. I’ll probably get around to fabbing up an airbox by the end of the week.
http://i.imgur.com/dPyuXJv.jpg
Here’s one thing that’s had me a tad miffed for a while. This goes for all you JHM supercharged folks too. The JHM oil cooler kit has these lines run through here. The problem I see is that this is supposed to be a cooling application but the lines run DIRECTLY in front of the exhaust manifold or headers if you have them. Even if I had ceramic coated headers, I’d be worried about heating up these lines. At least the one travelling back from the radiator because it almost seems to negate the effects of having the cooler in the first place… So I’ve been thinking about putting some heat shielding in between the lines and the exhaust manifold but I’m a little worried about it because the stuff I have leftover is for passive, radiative heat transfer, not direct contact. If I try and wedge a piece of shielding down there, it makes contact with the manifold so I don’t know if it’d end up being that effective. Nothing pressing of course, just something I’ve been thinking about. Maybe Jimmy would care to share his thoughts as he’s heat wrapped the piss out of pretty much everything on his car
