When people mechanically modify the 6hp valve body all they can do is bump the line pressure, change some springs and maybe drill out some of the vally paths. None of that is dynamic. That used to work great back before valve bodys were electronically controlled.
You can only mechanically bump the line pressure so much. Other wise the car will slam into R and D when just putting the car into gear. From there the cars would also slam into shifts at low low speeds.
With the JHM TCU tune you can control the pump speed, line pressure through all the RPM, hold the valves open as long or as short as you wish. You can control when the car shifts how fast the shift is and how much clamp force pressure is delivered on each shift and lock up of the tq converter.
Your able to speed up the shift add more line pressure. You can increase the clamp force and duration of the pressure.
With a mechanical approch you cant run any more line pressure after a certian limit because the car will just bleed off the extra line pressure. Normally you only see better shifts down low but no real change in the upper rpm. It might be slightly better in the upper rpm but the TCU has line pressure limits so if you go over those its just going to bleed off the extra pressure. With the JHM TCU tune the line, clamp and pump pressure limits are rasied along with all the needed supporting systems.
I had a modified valve body from level 10 it just kinda made the car slam into gear the car wasnt actually any faster and it still slipped on the 1-2 shift. After I got the JHM TCU tune. I now have higher shift rpm points and faster shifts with more clamping force. The cars 1/4 mile time was better as well.
