Stasis rear brake kit bias on B7 S4
Hopefully you guys can help me. I am looking at a used Stasis kit for my S4 which was a b6 a4 kit. Fronts are mono 4 with 355mm rotors and rears are 305mm. For the S4 stasis designed a larger rotor but since OEM was 300mm I figured I ask you guys if running 305mm with caliper moving out farther via bracket will not impact the balance if the bias. Thanks.
In comparison, a change in pad compound will have a larger impact than 5mm of rotor diameter… I know plenty of people with this setup and no issues on or off the track.
Thanks Koolade. I figured the fronts are worth buying it and not solid 305 rears. The seller wanted to sell the full kit from a B6 A4. So I finalized the front alcon mono 4 calipers and rotors.
