There are a lot of very smart people, engineers, and tuners on this board so I hope they can help me get my head around this concept. There is a lot of information over on the terminator 03-04 cobra boards which is mainly what I have been reading. What I gather is a cobra with a 100% stock ECU will run lean if switched from pump gas with a stoich of ~14.7 to a race gas such as VP MS109 with a stoich of ~13.4. The stock ECU has a ‘hard coded’ stoich value of pump gas at 14.7 and iterates/adjusts parameters based on sensor readings which is fine when the fuel assumed to have 14.7 actually is fuel that has a stoich of 14.7. However, when running pure VP MS109 the stoich of the race gas in the tank is 13.4, yet the stock ECU uses the now incorrect stoich of 14.7 to do its calculations. The general consensus is that this specific condition (totally stock ECU looking for 14.7 stoich when actually running a lower stoich found in various racing fuels) creates a lean condition and could be very dangerous.
Is this true, why? How dangerous could that be? What if a different race fuel was used that had a stoich of 14 which is more than the 13.4, but still not quite at pump 14.7? Is this concept of stoich a/f ratio generic enough to be applied across all makes/models assuming the ECU is 100% and not tuned?
