Hello folks - have 2007 s6 thats needs suspension refresh and I’m running into confilicting info, did search here, online, bilstein website etc.
Basically I’m trying to retain original ride quality or maybe slight improvement. I’m familiar with lowering springs, kw, bilstein b16s etc but is there anything similar to oem? are b8s only for lowering springs or our cars considered lowered already? Basically is there set of bilsteins I can just put in and have a good ride?
I had dealer pull front struts # based on vin and when i installed them the spring is no longer compressed, it actually just sits and can be moved by hand, which makes me thing I need new springs as wel? Have you ever heard/seen such a thing? The spring, fully installed on the strut is literally loose and offers no resistance at all, as if the strut piston is too long and doesnt compress the spring at all.
Again dealer matched vin with correct spring color code but they are in germany and it will take some time to get here. I had hr on previous cars and felt ride was too harsh.
Thanks!
