Stuck pinch bolts and my extractor tool set!
Someone local to me wanted me to replace their upper control arms because the bushings were shot. Here look:
http://i284.photobucket.com/albums/ll37/Jimmybones777/PinchBoltsRemovalpictures1_zpsdf655a07.jpg
Well the pinch bolts were stuck. The driver’s side was so stuck that it was going to break if I tried to use more force from either an impact gun or a breaker bar. The passenger side would spin slowly with a impact gun but it wouldn’t come out. We tried using penetrating oil for a week and all sorts of other ways of trying to get the stubborn bolts out. Later on I did some searching and found a company in Germany that sells an extractor kit for these pinch bolts. After six weeks this is what I got:
http://i284.photobucket.com/albums/ll37/Jimmybones777/PinchBoltsRemovalpictures8_zpsf943ad18.jpg
Here is the first part of the tool set hooked on to the pinch bolt and wheel bearing housing. The extractor was already run down when I took this picture.
http://i284.photobucket.com/albums/ll37/Jimmybones777/PinchBoltsRemovalpictures2_zpsa1b6fb29.jpg
That pulled the bolt out this far:
http://i284.photobucket.com/albums/ll37/Jimmybones777/PinchBoltsRemovalpictures3_zps62c69a73.jpg
Then I put this piece on to pull the bolt out farther.
http://i284.photobucket.com/albums/ll37/Jimmybones777/PinchBoltsRemovalpictures4_zps625a5d6e.jpg
That got the bolt pulled out a little farther.
http://i284.photobucket.com/albums/ll37/Jimmybones777/PinchBoltsRemovalpictures5_zps9762e9c1.jpg
Finally I used a set of locking pliers and a hammer to tap the bolt the rest of the way out.
http://i284.photobucket.com/albums/ll37/Jimmybones777/PinchBoltsRemovalpictures6_zpsf6921b5b.jpg
The pinch bolt was bent when I got it out but who cares since we were replacing the bolts and nuts anyways.
http://i284.photobucket.com/albums/ll37/Jimmybones777/PinchBoltsRemovalpictures9_zpseabee6cc.jpg
Here is a shot of how the first part of the tool works.
http://i284.photobucket.com/albums/ll37/Jimmybones777/PinchBoltsRemovalpictures11_zpsb6fd22ef.jpg
It pulls the bolt out by driving the extractor into the wheel bearing housing.
http://i284.photobucket.com/albums/ll37/Jimmybones777/PinchBoltsRemovalpictures10_zpsa1b88b01.jpg
Hopefully you guys enjoyed the pictures and the cool tool set because I know a lot of you guys have had to fight pinch bolts to get them out like me. By the way this tool set is not a dealership tool and I had never seen something like this until I started searching the internet and emailed some people.
