Stumped....
I spent the past week (with vacation time in between) trying to diagnose what my “knocking” noise is. It came on after a long hot drive up 95 to my parents house last Tuesday. My mom noted a knocking noise coming from the front of my car, I got out and heard it too.
Not knowing what it was, I parked the car in the garage and immediately asked some B6/B7 S owners via text. JimmyBones suggested that it might be my knock sensor and I might not have torqued it down to spec. He also came by with a VAG-Com to see if I had any trouble codes, I had 5: two knock codes, two vacuum leak codes and another that slipped my mind. I broke down the front end and took off the IM, tweaked around with the knock sensors, tightening them to spec (also had to do some preventative maintenance while car was down).
Today, I put everything back together and went out for a quick drive; everything checked out find. Tonight, I drove the Avant home from my parents and heard the knock noise again.
Here’s the video:
[video]https://www.youtube.com/watch?v=DstkTl6WDtY[/video]
Did a quick google search and found this DIY video:
[video]http://youtu.be/XOc_PHblvZQ[/video]
At the moment, I’m hesitant to break down the engine again to see what the noise is. Is it possible the intake flapper went out? The DIY video manipulation sounds SORTA like my noise. What do you gents think?
