Supercharger belt making squealing noises...again...
This is now the third time my supercharger belt is making squealing noises at RPMs above 3k. The last time this happened, my mechanic sprayed a minute amount of oil on the belt just to see and the noise went away for a few minutes (it was a very small amount just to confirm).
Anyway, since I needed to get some routine maintenance work done on the car at the time, I had the belt replaced just to be safe (small amount of work with the front bumper already off).
It was fine for a short while (about two months) and then I got a car wash and it started happening again.
What could be causing this? Is it the water spraying directly on the belt during a car wash that could be causing this?
