Have you ever taken part in any Dunning-Kruger research?
[quote]In what case can you put the same wheel from a turbo on a supercharger and in that case they would still share the same VE
What VE? Volumetric efficiency? That’s not actually a metric that is normally used for compressors. Engines or anything else with pistons, sure. Compressor blades…not really.
[quote]Looking at roots and c fuge maps you will see they carry a higher VE then conventional
Turbo maps. Turbos can get into the low to mid 70s in VE but there range of CFM and speeds at that point are limited. While the Cfuge or roots style carry a VE in some ranges in the 80% VE. If you knew what you were talking about you would have known this.
The efficiency of compressors is not measured in VE. Not at all.
Before you try to educate anyone you really should know what you’re talking about.
And compressor maps apply to the compressor itself only. Not to the unit (unit being the turbocharger or supercharger)
There is no inherent difference between compressor maps for centrifugal compressors whether they are mounted on a turbo or supercharger so your initial point (which you are straying away from slowly but surely) that the “clue” to what is the difference between SC and TC is invalid
Just for reference a Vortech map vs a Garrett map. There’s more efficiency lines on the latter but that doesn’t really matter.
http://www.greenringer.net/shoot/maps.jpg
So your point was?
[quote]It takes 2 turbos to do the work of 1 supercharger… win supercharger.
Sure you can use one big turbo but the lag and efficiency will be terrible.
If you’re talking about V engines then it is more convenient to use one turbocharger per bank, yes. Not really the point of the argument though is it. A single turbo is not more laggy or less efficient, au contraire, it would get twice the exhaust flow of 2 small ones but manifold design and space requirements favour the twin setup on V engines.
[quote]You can run boost at super low loads and tailor a boost curve of all supercharger apps getting close to 80+% efficiency.
And then you add parasitic loss to it. Compressor efficiency (which rarely if ever hits 80 percent by the way) is one small part of a larger equation. Superchargers have a lot of parasitic loss and turbochargers do not.
[quote]Hey genius did you know to recycle exhaust energy you need to create a restriction and to get that restricted path costs you a ton of energy and you loose even more VE.
Yes but the overall loss is a lot less than superchargers. Automotive knowledge 101 really. Overall efficiency turbochargers are simply better and to argue this point is like arguing the sky is green.
[quote]when you ACTUALLY READ A COMPRESSOR MAP for each you can see supercharged apps offer a much larger range for VE. So while the compressor map isn’t going to be the entire story it will be the start of the story. Since you don’t know that you don’t even know what your talking about.
- The efficiency lines on compressor maps are not VE. There is no frigging VE on a compressor map. Capiche?
- The compressor itself on a SC or turbo has similar efficiency and mid-70s are about as good as it gets.
- At the same boost level the VE of the ENGINE is better with a supercharger but this is offset by large parasitic losses.
- the last line applies entirely to yourself as I have just demonstrated.
Stay tuned as next week I might be on the side of the argument that intake manifold spacers are a complete waste of money.
