I got my 140k service a few weeks ago and the shop said that my front control arms are about to be in need of replacement. I’m planning on getting that fixed up in the spring then, and was wondering if I should just go ahead and replace the struts/shocks as well. By the time I get around to replacing them, I’ll probably be close to ~150k miles, and as far as I know, the entire suspension is original (bought used at 50k mi).
I have the factory, non-sport suspension now, but would like something a little sportier. I do mostly highway driving, and don’t track my car, so coil-overs are overkill for what I need, as well as out of the price range I’m looking at, especially since I’m planning on replacing all the front control arms and tie-rod ends since the bushings are nearly dead.
I was thinking of getting a spring and shock combo, so that I get a slightly lower stance and better handling from the lower ride height. I’m just not sure what would be a good option. Would it be better to get a set with shocks/springs together, or get them separate? I realize getting them separate gives me more options, but I mainly need something that isn’t really harsh as PA roads can be brutal sometimes, but I don’t want it to be as soft of a ride as it is now, because it takes away from the experience when trying to push it hard on the few chances I do have with spirited driving.
So, I’m hoping some folks here can offer some opinions and possibly help me out with what to get. I’m not rushed for time, as I said, this is likely 2-3 months out as I’ll be doing it at the end of winter or beginning of spring. No need to replace everything and get the new components covered with road salt through the winter. TIA
