TBA Values
Guys i just noticed the following and need your input.
I performed a TBA and before hitting the next button the values in the 2 sensors were 25ish% and 75ish% respectively. After the runs it went to 12ish and 88ish. I waited for about a min before exiting and it returned back to the original ones of 25-75. What is the correct value?
Thanks in advance for the responses
Did the fourth value say adaption OK? If so then don’t worry about the other values.
Yes…it read ADP OK.
The adaption OK is what your looking for. As long add the values your reading add to 100 your fine. They will change often if you keep doing the adaption.
