With any port adapter or media blast method you can’t see exactly what your spraying. You can estimate but unless you keep pulling the adapter off you’re not going to have the targeted method you would want. Not only that but EVERYONE I know that used or still uses media blast still has to go back and use a brush or scraper to actually get to all the areas and all the carbon.
Use the chemical method. Soak the valves, wait for the carbon to breakdown and melt off. Vac out the cylinder and your done. Go back with a washer fluid, fill the cylinders, agitate the fluid a bit and then vac that out. Much more efficient then blasting. If you soak the valves your getting all the valve, valve angles and spots you can’t see. You can’t blast media on the back side of the valve stem. You can only blast the angles you can see and the port adapter isn’t going to let you get the angles you need to target every angle.
One of the other last reasons I don’t like blasting. Is, like it or not, you can blast media into spots you can’t vacuum out and media gets trapped in the base of the valve. When that media can’t be pulled out and gets left behind it only has one place left to go and that’s into the cylinders when you start the car next time or turn over the motor to get to the next set of valves to clean. Where will it go after that? Into your cats.
Doing several header jobs. We have seen more than one set of cats with quite a bit of media in them from blasting done during carbon cleaning.
If you just think media blasting is the greatest thing. Then you should strongly consider pulling out your spark plug,s pulling the fuel pump fuse and turning the motor over several times looking to expel anything you can though the plug port. I do this even though I ONLY use the chemical method just as a safeguard.
