If you don’t live in the Chicagoland area, you don’t realize what we have to put up with as far as road conditions. Every year they dump thousands of pounds of salt on our roads to clear the ice and snow. The result is potholes, ridges, and warped roads that can beat any car up. Here are a few pictures that hopefully get across the point.
http://audirevolution.net/addons/albums/images/624015537.jpg
Here you can see that my old motor mounts are each in two pieces. If you are wondering whether or not I pulled them into two pieces, the answer is no. As soon as the third bolt holding in the lower motor mount bracket was removed, the whole thing fell out with the bottom half of the motor mount attached. This happened on both sides exactly the same way.
http://audirevolution.net/addons/albums/images/841007693.jpg
In this image you can see my two Hotchkis front sway bar brackets. This happened while inching out of a parking spot in a city alley. It sounded horrible!
http://audirevolution.net/addons/albums/images/808203313.jpg
This is what the original snub mount looked like when I took it off. It was barely in one piece still. Kind of looks like an old dog chew toy to me.
http://audirevolution.net/addons/albums/images/909438658.jpg
I can’t believe there is this much space between the OEM snub mount and the OEM snub bracket. I meant to take a picture of the 034 Snub Bracket with the Apikol Snub Mount but I forgot. However, there is no gap whatsoever, and man was it a pain in the ass to fit it together on the car.
http://audirevolution.net/addons/albums/images/52763417.jpg
Finally, here is the remnants of the main bolt for my Stern Rear Control Arm Links. This is the main bolt that connects the two ball joints connecting the control arms to the sway bar. This is a big fucking bolt too, it’s an M10x1.5 65mm, if you go to any hardware store or auto store I guarantee you they won’t have this bolt. I spent half a day driving everywhere looking for a bolt to replace this one and it just wasn’t happening. Any place that had the bolt in this size only had them partially threaded which doesn’t work in this application. Fortunately, I contacted JHM and they said Stern would warranty the bolt and replace it for free.
This is just an idea of what you get with Chicago driving.
