Thanks for that, managed to get 20 mins to see if i could test the wiring, no luck. Think I need to rethink my testing method, the little bits of metal I pushed in the pins either end might not have been making contact, so i’ll clean them up and try again later.
i did discover a new bit of spanner monkey genius on the loom on that side i have all the problems on.
I don’t know what the bracket is supposed to be for on the back of the head, but some moron has cut it, bent it slightly and left the wiring loom rubbing on it and a massive sharp point sticking out.
Good Spanner Monkey. Well done!
For whatever reason they’ve been in there, they’ve butchered the loom as well. I’ve removed some of their dodgy taping to reveal the extent of it.
I’ve bent the remaining bracket down so i can get in there with cutting myself and I’ll investigate the loom there I think. Make sure there’s no broken wires and tape it all up properly.
Not exactly factory!!. Morons.
