Hey everyone,
I’ve been poking around this forum for a while now while I was looking at cars to buy as I wanted to get some info about the s6’s.
All very helpful.
I decided to bite the bullet in August last year and picked up a fairly high mileage 07 5.2 S6 for pretty cheap.
I knew it had issues as it had a little oil leak and it was throwing codes for some things. But I bought it anyway. I’m far from scared of a spanner thankfully and don’t mind working on it myself.
So the fun has been on going, first thing I did was sort out the errors it had, bad cam position sensor, bad cam actuator. Then I tried to sort out the air con not working, which ended up being a new condenser, dryer, pressure switch, and still isn’t working because I had to do other things, more importantly.
The little oil leak decided to turn into a massive one (like pissing oil out) one day, had to get it recovered home and dived into that. It ended up being the oil cooler seals, so I pulled it all apart and sorted that out. (Ball ache of a job really, its not the easiest getting the oil cooler out with the motor in the car, but definitely doable. Still haven’t refilled the air con to see if that’s fixed). While I had it in bits for this, I tackled the carbon clean, just went the walnut blasting route and gutted the intake as there were some broken flaps… blasting turned out nice actually.
Then it decided to throw a CEL while getting MOT’d but I knew it was only an intake runner position sensor on the intake manifold which I think I knocked while I was cleaning and gutting it. it had throw that code a few times occasionally so I replaced the sensor and went to get it retested.
Then it decided to blow the radiator while getting tested again so I had to pull the front off again and sort that out. (Glad I hadn’t filled up the air con yet. LOL)
All the while I have been chasing some misfires that started since I carbon cleaned it, I changed the plugs and coils, but I think that was down to dirty fuel injectors in the end, as a few bottles of Redex later that’s cleared up, at least I haven’t seen a cylinder 1 misfire since, but if you read the below… maybe that was an electrical fault.
Now it’s decided it wants to throw the EPC light. We went to visit some family and it was fine, but firing the old knacker up to come home it decided it was going throw the light and run like only 1 bank was firing. Switched it off, fired it back up and it was in limp mode. switched it off and back on and it was running fine, but the EPC light stayed on.
The joys of V10 life. lol
I got VCDS on it today and ran a full test off, see below and there’s a couple of things on here that I’m not entirely sure about.
The cam actuator and position sensor short to ground explains a few issues it occasionally throws codes for. Actuator low codes usually, but they would clear fine and running the output tests in VCDS today I could here the solenoids activating on both banks, but then it’s not throwing that code right now.
The EPC light seems to be brake related, but the ABS controller is not reporting any issues.
The big issue for me is 049429 - Second (Slave) Engine Control Module
U0115 - 008 - No Communication - Intermittent
That kind of explains why it seemed to be running on one bank.
While I was on today, I removed both ECU’s and cleaned them up including the contacts in the plugs and on the ECU, there didn’t seem to be any water ingress or corrosion so I don’t think that’s the issue.
I have a sneaky feeling from the short to ground and the No comms with ECU 2 issue that I am going to end up chasing an electrical fault somewhere. (But where?) The plugs on the sensors are fine, none of the wires appear to be damaged at the sensor end and the ECU end.
There’s also some other weird issues that have started like the Heater control valve has decided that its only going to blow hot air, which I’m aware could be because it’s a bit corroded inside, but I recently had that apart and cleaned it all up while I was working through the AC issues so I don’t think it’s that, possibly another electrical issue some where?
So I’m wondering really, what do you guys think? Any ideas on what to check next?
Any help much appreciated. I’m loving S6 life TBH and I want to get this car totally sorted so I can keep it for quite a long time, there not so many around now and I think mental motors like these things are worth trying to save now. won’t be long before you can’t have anything like this anymore.
Cheers guys.
Chris
Sunday,20,August,2023,15:26:56:00009
VCDS – Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 22.10.0.1 (x64)
Data version: 20221026 DS344.0
VIN: WAUZZZ4F07N097128 License Plate:
Mileage: 227620km-141436mi Repair Order: 20230820.002
Chassis Type: 4F (4L0)
Scan: 01 02 03 05 07 08 09 0E 0F 11 31 15 16 17 19 37 42 46 47 4F
52 53 55 56 61 62 65 6C 6D 72 76 77
VIN: WAUZZZ4F07N097128 Mileage: 227620km-141436miles
02-Auto Trans – Status: Malfunction 0010
07-Control Head – Status: Malfunction 0010
08-Auto HVAC – Status: Malfunction 0010
0F-Digital Radio – Status: OK 0000
15-Airbags – Status: OK 0000
19-CAN Gateway – Status: Malfunction 0010
46-Central Conv. – Status: OK 0000
55-Headlight Range – Status: OK 0000
56-Radio – Status: OK 0000
61-Battery Regul. – Status: OK 0000
65-Tire Pressure – Status: Cannot be reached 1100
6D-Trunk Elect. – Status: OK 0000
72-Door, Rear Right – Status: Malfunction 0010
76-Park Assist – Status: Malfunction 0010
Address 01: Engine Labels:. 07L-910-552-BSM1.clb
Part No SW: 4F1 910 552 C HW: 4F1 907 552
Component: 5.2L V10/4V FSI 0060
Revision: 59H14— Serial number:
Coding: 010D0003190F0160
Shop #: WSC 01089 210 97503
VCID: 24475997E7DBF6ADC6-8070
VINID: 9D196AAAA11600778024704220F3ADC385
5 Faults Found:
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 227619 km
Time Indication: 0
Freeze Frame:
RPM: 756 /min
Load: 54.5 %
Speed: 0.0 km/h
Temperature: 75.0 C
Temperature: 53.0 C
Absolute Pres.: 1010.0 mbar
Voltage: 11.684 V
005715 - Please check DTC Memory of ABS Controller
P1653 - 008 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 227619 km
Time Indication: 0
Date: 2023.08.20
Time: 14:31:57
Freeze Frame:
RPM: 654 /min
Load: 34.9 %
Speed: 0.0 km/h
Temperature: 75.0 C
Temperature: 53.0 C
Voltage: 11.684 V
008328 - Bank 1 Camshaft A (Intake) Position Actuator
P2088 - 002 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 5
Reset counter: 255
Mileage: 227622 km
Time Indication: 0
Date: 2023.08.20
Time: 14:39:21
Freeze Frame:
RPM: 1614 /min
Load: 45.9 %
Speed: 14.0 km/h
Temperature: 99.0 C
Temperature: 36.0 C
Voltage: 13.843 V
001152 - Coolant Fan Control Circuit 1
P0480 - 002 - Electrical Malfunction - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 227624 km
Time Indication: 0
Date: 2023.08.20
Time: 14:52:55
Freeze Frame:
RPM: 594 /min
Load: 18.4 %
Speed: 0.0 km/h
Temperature: 105.0 C
Temperature: 46.0 C
Voltage: 13.716 V
P1923 - 008 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 227626 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 63.0 C
Voltage: 12.192 V
Readiness: 0010 1001
Part No SW: 4F2 910 156 M HW: 09E 927 156 C
Component: AG6 09E 5,2 FSI RdW 0030
Revision: --H01— Serial number: 0098451
Coding: 0000001
Shop #: WSC 02325 785 00200
VCID: 2F6DA6BBBE1D45F52B-807A
1 Fault Found:
006231 - Load Signal
P1857 - 001 - Error Message from ECU - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 227619 km
Time Indication: 0
Date: 2023.08.20
Time: 14:32:03
Freeze Frame:
RPM: 608 /min
RPM: 640 /min
RPM: 0 /min
(no units): 30.0
(no units): 93.0
Temperature: 40.0 C
T.B. Angle: 0.0
Address 03: ABS Brakes Labels: 4F0-910-517.clb
Coding: 0020920
VCID: 3169A0C3A82953053D-8064
No fault code found.
Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0220
Revision: 31050601 Serial number: 10601100620900
Coding: 0000147
Shop #: WSC 02323 785 00200
VCID: 63C51A8BA255B195FF-8036
Subsystem 1 - Part No: 4F0 910 131 E
Component: FBSAUDIC6 EZS H45 0080
Subsystem 2 - Part No: 4F0 910 220 D
Component: FBSAUDIC6 IDG H01 0040
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F1 910 732 E HW: 4E0 035 729 A
Component: Interfacebox H43 5570
Revision: 00000000 Serial number: 351LT067532067
Coding: 0011002
Shop #: WSC 02335 785 00200
VCID: 2643439F91E704BDD8-8072
Subsystem 1 - Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H01 0060
Subsystem 2 - Serial number: 00000000606872
Subsystem 3 - Serial number: 0105.12.060000000100010718
Subsystem 4 - Serial number: 010718
2 Faults Found:
01325 - Control Module for Tire Pressure Monitoring (J502)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 215
Mileage: 227619 km
Time Indication: 0
Date: 2023.08.20
Time: 14:12:50
02259 - Information Display and Control Head (Front) (J685)
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 0
Mileage: 227619 km
Time Indication: 0
Date: 2023.08.20
Time: 13:47:42
Freeze Frame:
Bin. Bits: 0000010
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 A HW: 4F2 820 043 Q
Component: KLIMABETAETIGUNGH30 0020
Revision: 00000052 Serial number: 00000030186710
Coding: 0525578
VCID: 1C376177DFABCE6D7E-8048
1 Fault Found:
00797 - Sunlight Photo Sensor (G107)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 6
Reset counter: 0
Mileage: 227621 km
Time Indication: 0
Date: 2023.08.20
Time: 14:36:47
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 K HW: 4F0 907 279
Component: ILM Fahrer H17 0240
Revision: 00000000 Serial number: 4F0907279
Coding: 0015121
Subsystem 1 - Part No: 4F2 910 113 B Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H04 0190
Coding: 00064784
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00146221
Shop #: WSC 02335
Address 0E: Media Player 1 (R199) Labels:. 4E0-035-785.lbl
Part No SW: 4E0 035 785 F HW: 4E0 035 785 C
Component: SG ext.Player H20 0850
Revision: 00000000
Coding: 010000
Shop #: WSC 00000 000 00000
VCID: 2B55B2AB4A0539D507-807E
Address 0F: Digital Radio Labels: None
Part No SW: 4E0 910 563 C HW: 4E0 035 563
Component: DAB-Tuner H41 0830
Revision: 00000001 Serial number: KE1276U8001167
Coding: 0000001
Shop #: WSC 02324 785 00200
Address 11: Engine II Labels:. 07L-910-552-BSM2.clb
3 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 227619 km
Time Indication: 0
Date: 2023.08.20
Time: 14:31:57
Freeze Frame:
RPM: 673 /min
Load: 100.0 %
Speed: 0.0 km/h
Temperature: 75.0 C
Temperature: 53.0 C
Voltage: 11.557 V
005000 - Control Module Malfunction - DBW Throttle Monitoring
P1388 - 001 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 227619 km
Time Indication: 0
Date: 2023.08.20
Time: 14:31:59
Freeze Frame:
RPM: 1323 /min
Load: 100.0 %
Speed: 0.0 km/h
Temperature: 75.0 C
Temperature: 52.0 C
Voltage: 12.700 V
000839 - Camshaft Position Sensor (G163)
P0347 - 002 - Short to Ground
Freeze Frame:
Fault Status: 01100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 227619 km
Time Indication: 0
Date: 2023.08.20
Time: 14:32:23
Freeze Frame:
RPM: 1001 /min
Load: 47.4 %
Speed: 0.0 km/h
Temperature: 75.0 C
Temperature: 54.0 C
Voltage: 11.811 V
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
Component: 4E AIRBAG AUDI8RH30 0280
Revision: 09H30000 Serial number: 0037LD0M023S
Coding: 0013381
VCID: 295948A380F92BC5F5-807C
Subsystem 1 - Serial number: 6332CSME1449491F8
Subsystem 2 - Serial number: 6342CSME152D1B6CD
Subsystem 3 - Serial number: 6352QSME1B483E4BX
Subsystem 4 - Serial number: 6362QSME1A735333D
Subsystem 5 - Serial number: 63734SME11735063R
Subsystem 6 - Serial number: 63834SME21112753O
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenks ulenmodul H08 0230
Revision: 00H08000 Serial number: 90026063350328
Coding: 0102142
VCID: 66C3039F5167C4BD18-8032
Subsystem 1 - Part No: XXXXXXXXXXX
Component: Lenkradmodul H07 0090
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 930 C HW: 4F0 920 980 P
Component: KOMBIINSTR. M73 H19 0120
Revision: 00000000 Serial number: 5H234TMC6
Coding: 2049448
Shop #: WSC 57722 067 57207
VCID: 23455A8BE2D5F195BF-8076
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 HW: 4L0 907 468
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0900B06B298009
Coding: F555FEF7303A06
Shop #: WSC 00088 210 90914
VCID: 6CD771B74F8BFEED4E-8038
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 214
Mileage: 227619 km
Time Indication: 0
Date: 2023.08.20
Time: 13:35:30
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 887 T HW: 4E0 919 887 L
Component: MNS ECE H48 1030
Revision: 00000000 Serial number: 364LZ067621556
VCID: 3E738BFF6977BC7DB0-806A
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0120
Revision: 00000000
Coding: 0003706
Shop #: WSC 02327 785 00200
VCID: 2C57B1B78F0B3EED0E-8078
Part No SW: 4F0 910 289 B HW: 4F0 907 289 B
Component: Komfortgeraet H22 0170
Revision: 01700022 Serial number: 01025492510000
Coding: 3287803
Subsystem 2 - Part No: 4F0 910 177
Component: Innenraumueberw.H01 0020
Address 47: Sound System Labels: 4F0-910-223-BO.lbl
Part No SW: 4F0 910 223 J HW: 4F0 035 223 G
Component: DSP-High C6 H10 0240
Revision: PROD_01 Serial number: 00000000006734
Coding: 0000117
VCID: 25414493ECE10FA5D1-8070
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000343309
Coding: 0011104
VCID: 5EB32B7F89379C7DD0-800A
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0120
Revision: 00000000 Serial number: X&
Coding: 0003706
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 C HW: 4F0 907 801 A
Component: EPB CDEC0080 H04 0080
Revision: --H04—
Coding: 0008021
VCID: 204F5587F3C3EA8DA2-8074
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 F
Component: Dynamische LWR H02 0010
Coding: 0000003
VCID: 3D718CF36471A765A9-8068
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4F0 035 541 H
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 394LW06B000906
Coding: 0000001
Address 61: Battery Regul. Labels: 4F0-910-181.clb
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: J0644 BEM H12 0590
Revision: 00000000 Serial number: 00000000160155
Shop #: WSC 00411 210 81348
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 2612032297
Coding: 344630393135313035442056413032363132303332323937
Shop #: WSC 00000 512 00290
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0050
Coding: 0003114
VCID: 2E53BBBFB9174CFD20-807A
Address 65: Tire Pressure
Cannot be reached
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4F0 910 441 A HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12— Serial number: 525PA8-J6930WT
Coding: 1020205
VCID: 1E336B7FC9B7DC7D90-804A
Address 6D: Trunk Elect. Labels: 4L0-910-945.clb
Part No SW: 4F9 910 591 HW: 4F9 827 851 E
Component: ValeoHeckdeckel H21 0280
Revision: --H21001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
Subsystem 1 - Part No: 4F9 910 592
Subsystem 2 - Serial number: E5030100B
Subsystem 3 - Serial number: RD04.12.06–H21001001A0050
Subsystem 4 - Serial number: 1A0050
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0050
Coding: 0003114
1 Fault Found:
02110 - Window Regulator Switch
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 253
Mileage: 227534 km
Time Indication: 0
Date: 2023.08.19
Time: 13:30:34
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 G HW: 4F0 919 283 G
Component: Parkhilfe 8-Kan H12 0060
Revision: 00H12000 Serial number: 06330633302239
Coding: 0221116
Shop #: WSC 131071 1023 2097151
VCID: 285F4DA79BF312CDEA-807C
1 Fault Found:
01626 - Sensor for Parking-Aid; Front Right (G252)
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 215
Mileage: 227619 km
Time Indication: 0
Date: 2023.08.20
Time: 13:47:06
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4E0 910 336 M HW: 4E0 862 335
Component: Handyvorb2 H18 1130
Revision: 00000000 Serial number: 00000005134703
Coding: 0010920
End-------------------------(Elapsed Time: 03:23)--------------------------
