I’ve been talking with this guy kicoro1 for a while now, he is a super nice guy, quick to respond, I am purchasing a VFIZ within the next month, I’ll be sure to post videos and whatnot you guys may be curious about.
Considering this for my S4. I saw the unit was now 200. Is that a plug and play with the sweeping needle and I can get basically all the pick ups that I can see in vag com.
For that price im very interested. I just want to make sure Idont have to spend extra.
last question. What is the difference in being able to control the unit via MMI do you need special software to control VFIZ through the MMI if you want
ok this all makes sense now. I thought you could use a RNS-E. Good thing I asked.
for the price your asking this is something Im going to get. Im on the road for the next few days but I will be picking this up if the sale lasts through the holidays.
Just to make sure I understand if I have a NA S4 it will read the intake air temp from the MAF and the throttle input and all the other supported standard things you showed in the video. The unit is reading off the stock sensors
So another example if like I had a 2.0t A4 it would pick up boost from the oem sensors right. So I dont have to by any extra sensors just the box. VFiz is basically able to read off the stock sensors like vag com can
Last question. Whats the difference between the color and the red
To use RNS-E you should be on specific screen and it wasn’t be convenient to take hand from steering during drive… that would be worst option.
VFIZ can read throttle, intake temp and much more (just by OBD) in all cases incl. S4
It can also pick boost from OEM sensor but OEM sensor is limited to boost (no vacuum reading, vacuum in only possible via dedicated sensor)
Color is related to highline Color FIS (White/Red/Yellow and high resoulution),
Red is related to lowline, lower resolution Red/Yellow only FIS - you can change this later yourself by firmware upgrade
Not sure what which holidays you mean, we can’t guarantee that, you can place order now and pay later,
it is up to you.
