This would be for an intake system( intake at front of car, filter and box, tube that goes from box to turbo intake)
The battery in the TTS is in the trunk so I’ve got quite a lot of room on that side of the engine. I should be able to rig up a holder for the logger part.
What type of measurements did you end up taking; what I’ve come up with so far is:
outside temp
Stock box: air temp at entrance to box, pre filter / temp post filter at the mid point of the turbo inlet tube (closest point to the engine but not right next to the turbo)
Aftermarket air box:
Pre filter temp inside box
Post filter inside box
Post filter at mid point of tube(inside)
Outside temp of tube at same point of inside measurement
Anything else I’m missing? MQB platform is the data logging the same?
