Hey guys,
I have had a couple of times when the old temp gauge started to climb up to 3/4 hot. It normally sits at just over halfway or about 92degrees C. So thought I’d do a thermostat change. The coolant also looks pretty weak (mainly water)so that’s gotta go.
Looks like a simple process to put the housing and drain. Any tips for filling the coolant?? Also how much coolant should I expect to use? Any specific type I should use? I don’t need much anti freeze properties as it’s not super cold we’re i am.
Many thanks
Neil
