Throttle Body Connectors?
I have been having intermittent issues with my 2009 S6. Every once in a while, it goes into limp mode, displaying TPMS, EPC, and Stability Control failures. When this happens, cruise control is disabled, and the car will only barely reach 60mph, with barely any throttle response.
I only have a generic code scanner, and it is displaying P2101, P0121, and P0221. These codes are only present one at a time. If I clear the code, the same code may come back on restart, or it may display one of the others, but the symptoms are the same.
I had this same problem back in October. Took it to the dealer, and after several days of diagnosis, they cleaned the electrical connections to the throttle body as well as a loose ground, and reset the throttles. This only “cured” it for a while and now the problem is back with greater frequency.
From the research I have done so far - I am guessing that I have the infamous VAG throttle body connector issue. Can any of you tell me the correct parts and/or where to get the kit to fix this? I will need two plugs and the 12 wires with connectors so that I can splice in new connectors and hopefully cure this problem permanently.
Thanks!
