Thumping/bumping sound and feel when turning.
This issue started the the first of the year when the temps here stayed in the 20’s-30’s. I was leaving work and made a full lock left turn and noticed a thumping/bumping sound from the front passengers side wheel, like I had a flat tire. I repeated the same turn several times and it did the same thing. Could it just be the front end out of alignment, or something more? A little background complete front suspension refresh done 11/2014, inner and outer tie rods done 11/2013. I did take it to an alignment shop close to my job, but not one that I normally go to. They did not find anything and said the alignment and tire wear were perfect. Well I know the wear isn’t perfect the passengers side tire has a little bit more wear than the drivers side.
