I though I should let you guys know that on my 3.0, I had the timing belt done at 65k. At 65k, it was MORE than due for replacement. Mine was cracking and the edges were starting to fray.
Hopefully JHM will offer a timing belt kit for you guys. According to Audi, you need a special cam lock tool which is über expensive and hard to find. You only need it if you are replacing the came seals. The guy that did mine is a season 2.7t owner and he owns his own shop. He told me the cam seals don’t need to be done unless they are leaking. Imdont know if this is really true or not, but when I sold the car at 77k they were fine. Point is, you don’t need the slick tool thus making this DIY-able. My guy just marked the positions of the old belt on each gear and then transferred that to the new belt.
Just letting you guys know, so you don’t have a snapped belt spoil your fun.
