I am replacing the o-rings on the 4 VT solenoids because of oil leaking from them. On the last one, located in no mans land passenger side next to the spark plug, I lost the screw. Didn’t hear it fall, can’t see it inside the hole. I did stick a magnet down there, but nothing.
I used a magnetic torx on the others, but this one has the coolant tank bracket in the way, so i used a shorter torx and loosened it while pulling on the solenoid so the screw would remain in the solenoid bracket hole. So much for great plans.
Is there a hole somewhere in the solenoid hole where the screw could have gone? it’s really hard to see in there. If there is, where does it go? If not, I can just replace the screw.
