Transmission fluid flush
Had my car over at Chicago Performance and Tuning for my 55k service (new plugs, oil, filters, etc.).
While there, had new front 355mm rotors and Carbotech AX6 pads installed. Car was raised up a little bit too to address a rear rubbing issue. Got rear sway modified so it could be reverted back to stiff setting without grinding on axle. Aligned and balanced. Decided to get a transmission fluid flush and replace as well.
All I can say is massive improvement. It feels like a new car.
Transmission service was undoubtedly the best part. Not only are shifts quicker, they are perceptibly smoother. No more clunkiness or hesitation in any gear. Everything feels much more crisp, instantaneous and direct. I would absolutely recommend the service for those with the ZF-6 speed. I was worried that I was just throwing money away and would not see any tangible beits but I was pleasantly surprised. Hopefully one day CV can work his magic and perfect this transmission.
Fingers crossed, APR has the updated C6 tune ready by fall and I’m able to post up some faster times before winter.
On a side note, there was a 991 GT3 and 991 GT3 Cup car there. Both white. Same owner. I’d be quite content with one.
