Thats right kids live at… say… oh… 4am. Im going to post glamor shots of why your timing tensioners fail.
complete with pictures and media hype… ok no hype… but pictures for sure.
oil passages all gummed up?
Nice call beem. I have to say bad oil will stop them from being able to do there job but from what Ive seen they fail due to other reasons. I don’t want to ruin the possible spoiler thats comming
yeah I always figures this…
bad oil, gummed passages
gummed passages, low pressure at startup
low startup pressure, low chain tension
low chain tension, chain smacks guide
chain smacks guide, chain rattle
chain keeps smacking guide, guide breaks
guide breaks… well fuck your life
interested to see what the other cause/s could be
I’m gonna take that guess and reverse it bad guide, guide fails then intern causing tensioner to fail!
In for this, and nice theory beem!
Always good stuff guys. Ill have to get more into this later. Here are a few pictures to show you what were working with.
Here is the tensioner 1 of 4. Still in its spot on the motor
http://audirevolution.net/addons/albums/images/379849605.jpg
I know you can’t see all of them but you can see the chain layout and you can still see at least 1 tensioner
http://audirevolution.net/addons/albums/images/853321513.jpg
Here is a little peak on what it looks like when you break it apart
This starts the “chain” of why the tensioner fails. More to come.
http://audirevolution.net/addons/albums/images/58878917.jpg
a little more apart.
http://audirevolution.net/addons/albums/images/730278402.jpg
now this is what the receiver site looks like
http://audirevolution.net/addons/albums/images/868203854.jpg
hmm that garage looks familiar, any chance that engine block has a hole in the passenger side?
i have a vast recollection of this engine
Back to the tensioners.
what were looking at here is the back of the tensioners. You can see there is a oil port on them. Oil comes up from the pan to pressurize these. You can see how small the ports are on these.
http://audirevolution.net/addons/albums/images/483358255.jpg
The oil goes into the block, then into the port on the tensioner and threw this orifice
http://audirevolution.net/addons/albums/images/752554489.jpg
We saw this before in the picture above.
fingerbanging a 4.2.
NSFW!
Good stuff, wonder if this is going on with my car. lol
Lets do a compression test on it. That should get more information. I still think your car is fine-ish lol.
I do need a compression test, just have to find the time and do it.
It only took me about 45min to an hour. Really wasn’t bad. I did min by just jumping the starter rather then pulling the fuses and cranking through the ignition. I only did a dry test though, but going back I’d really like to do a leakdown test as well. It’d defenitely be worth the time while you’re in there.
Someone needs to make a compression test DIY/FAQ. Such an important part in determining the health of these motors
Great point and great idea. I think the biggest issue for real non mechanic guys will be getting the tools to do it. Then just making sure its done right, as just like any test sometimes people can make sure to do a test and fool themselves into the data they want to see.
Yea, I found a bit of conflicting info out there when I did my compression test, it would be nice to have one clear diy on it though. Tool wise it didn’t seem that bad really (besides needing a compression tester). For me, all I did was disconnect the battery, pull the coil packs and then all the spark plugs (obviously keeping them numbered and in order for reference), then made sure throttle plate was partially open, and I just “jump started” the started motor by making a little set of wires (plug is behind the airfilter next to the O2 sensor plug, for the 4.2 S4 at least) and let it cycle through a couple of times once the compression tester was screwed into the right cylinder. It prevented needing to pull fuses or have someone crank the car at the same time.
Hopefully this was all okay, Halik kinda helped me through it as he had just posted on AZ that he had done a compression test on his new motor. I should have also done a wet/leakdown test, but I only did a dry test at the time.
