UBLY Results April 26th 2014 - GIAC Stage II B8 S4
Hey guys,
Here are the results from the day. Made over 35 passes. I am running the new AWE coolant pump and needless to say it combined with the Cold Front System is WORKING big time. I’ll let the slips speak for themselves. The guys at the track could not believe the car did over 30 passes in a couple hours back to back and was flawless. I think they have a new appreciation for Audi’s.
New Personal Best - Possible Fastest Trap Record
E.T. - 11.6478
MPH - 119.77
11.64
http://youtu.be/ab-AODPeeGU
11.653
http://youtu.be/VaKZ9faOuO8
11.655
http://youtu.be/SdFNPL8sroc
This is with a 1.7094 60’! if I could have landed my best 60’ of the day which was a 1.6628, it might have been perfect.
  • 7 Passes under 11.7
  • 7 passes under 11.8
  • 16-18 passes between 11.80-11.99
Setup:
  • GIAC/AWE Stage II - 104 Tune
  • DSG Tune
  • JHM LW Rotors
  • Eurocode Headers
  • Roc- Euro Intake
  • AWE Cold Front System - With AWE Cold Front Coolant pump
  • Enkei RPF-1 18x8 Wheels
  • Continental DW 245x40x18
  • 14 gallons of pump 100 Octane mixed with 2 gallons of e85 - ran with about half a tank down to empty. I went through half a tank of gas on these passes.
DA shows around -62 calculated using:
  • 42 degrees
  • 787 elevation
  • 85% humidity
  • 29.92 barometric pressure
11.6xx Passes:
http://i1020.photobucket.com/albums/af323/jeff24680/P1040070.jpg
11.7xx Passes:
http://i1020.photobucket.com/albums/af323/jeff24680/P1040073.jpg
11.8xx Passes:
http://i1020.photobucket.com/albums/af323/jeff24680/P1040072.jpg
