Ultimate B7 A4 2.0T Information Thread
This is going to be a working list and I am simply compiling data into one place. As i continue to researching this i will update with more information as new information is given.
Hey Guys! I have been a long time behind the scenes reader on here and feel that it is my time to give back to the community. There is a lot of threads out there with useful information but they are spread all over the place. Its time for a centralized location.
Cam Follower: The Cam Follower in the 2.0T is a very well known part that fails. The normal recommended time frame to change them is 20k-25k miles but results differ depending on driving style. The reason the Cam Follower fails is easy- Metal on Metal friction. Some research stated that a slight oil starvation could also attribute to the failure.
The Fix: Check your Cam Follower frequently, if its starting to show signs of wear change it. The part cost roughly $40.00 depending on where you get it from. It would be a wise choice to keep one on hand.
Gear Ratios:
A4 2.0T Quattro (B7) 3.667 2.053 1.423 1.065 0.853 0.730 (6-Spd)
Final Drive: 3.89:1
Gear Box Codes: GVD, GVE
Timing Belt Parts and Part Numbers
• 1 x Timing Belt (2.0T FSI) (Continental, 06D109119B)
• 1 x Timing Belt Roller (INA, 06D109244E)
• 1 x Timing Belt Roller (NTN, 06B109244)
• 1 x Timing Belt Tensioner (NTN, 06D109243B)
• 1 x Water Pump (2.0T, Metal Impeller) (Geba, 06F121011)
• 1 x Accessory Drive Belt (1570mm) (Continental, 06D903137C)
• 1 x Crankshaft Seal (35x48x10) (Elring, 038103085E)
• 1 x Camshaft Seal (47x10x32) (Elring, 038103085C)
OPTIONAL Timing Belt Kit Hardware:
• 6 x Bolt (M8x16) (Genuine Audi VW, N91143901)
• 1 x Bolt (M8x45) (Genuine Audi VW, N10268304)
• 1 x Nut (M8) (Genuine Audi VW, N01100845)
• 1 x Washer (M8) (Genuine Audi VW, N0152785)
OPTIONAL Timing Belt Kit Components:
• 1 x Genuine G12 Plus Plus Engine Coolant (1 Gallon) (Genuine Audi VW, G012A8G1G)
• 1 x Thermostat (A4 B7, 2.0T) (Behr, 06D121111G)
• 1 x Accessory Drive Belt Tensioner Assembly (Latest Revision) (INA, 06B903133E)
• 1 x Timing Belt Service Sticker (Genuine Audi VW, 059010158A)
Data Logging and understanding Vag-Com Measuring Blocks
Below are slides from a PDF on Ross-Tech’s Website. The slides will help you understand what each Measuring Block does. I would have put the slides on here but there was no easy way to do this as they are locked and not linkable. i will work on a solution to get the slides on this thread but this will work for now.
Group 000, General Engine Data, (No Normalization)
Groups 001 - 009 General Engine Data
Groups 010 - 019: Ignition & Misfire Detection
Groups 020 - 029: Knock Control
Groups 030-049: Mixture Control, O2S Heating, Catalytic Converterl
Groups 060 - 069: Throttle Valve Control
Groups 070 - 079: Emission Control Systems (EVAP, Sec. AIR, EGR)
Groups 080-085: Control module identification
Groups 090 - 098 Camshaft & Intake Manifold Control
Groups 099 & 100: Compatibility Groups
Groups 101 - 109: Fuel Injection
Groups 110 - 119: Load Registration & Boost Pressure Control
Groups 120 - 129: Communcations between Control Modules
Groups 130-137: Engine Cooling
Groups 140-147: BDE
Groups 160-169: Lambda control / SULEV-ULEV
*Reserved for more information
Snagged this one from Jake@JHM. Great Information regarding Spark Plugs.
OEM Replacement Spark Plugs:
There are two different spark plugs that came in the B7 A4 2.0T. Therefor both choices will be a direct replacement for your vehicle. We have had great experiences with both of these manufactures and choice will ultimately come down to preference.
Bosch - FR6KPP332S Long Life Platinum (Heat range 6)
http://jhmotorsports.com/shop/catalog/images/Bosch_FR6KPP332S_2.0t.jpg
Click HERE for more information!
NGK - PFR7S8EG Laser Platinum (Heat range 7)
http://jhmotorsports.com/shop/catalog/images/NGK_Plug.jpg
Bosch - F6DTC Tri-Electrode (Heat range 6, same heat range as stock) Note: This is a good lower cost replacement for stock cars or cars mostly stock with just a tune.
http://jhmotorsports.com/shop/catalog/images/Bosch_Tri_Electrode_Spark_Plug.jpg
Higher Boost Applications:
The following plugs are pre gapped at a perfect width to keep misfires away on high boost applications. We use these plugs in our race cars and customer’s cars with great success.
Bosch - F5DPOR Platinum Sidefire (Heat range 5, one heat range colder than stock)
http://jhmotorsports.com/shop/catalog/images/bosch_platin_web.jpg
Bosch - FR5DTC Tri-Electrode (Heat range 5, one heat range colder than stock)
NOTE: The spark plug torque spec is 30nm or 22 Ft-lbs. Remember to use Anti-Seize on the threads for easy removal and corrosion protection.
200 hp, 2.0 liter 4-cyl. turbo engine.
Engine Data:
Maximum Output SAE net hp@RPM 200 @ 5100-6000
Maximum Torque SAE net lb-ft@RPM 207 @ 1950-5000
Number of Cylinders: 4
Displacement CID (cm3) 121 ( 1984 )
Stroke in (mm) 3.65 ( 92.8 )
Bore in (mm) 3.25 ( 82.5 )
Compression Ratio 10.5:1
Fuel (Recommended Minimum) 91 Octane Premium Unleaded
Dimensions:
Length (with LP bracket) in (mm) 180 (4586)
Width (across mirrors) in (mm) 76.3 (1937)
Height w/ Roof Rails-Avant in (mm) 57.2 (1453)
Height -Sedan in (mm) 56.1 (1427)
Height -Cabrio in (mm) 59.7 (1518)
Turning Circle Diameter ft (m) 36.4 (11.1)
Capacities:
Fuel Tank: FWD Quattro
-Total Capacity gal/litres 18.5 / 70.0 16.6 / 63.0
-Reserve Approx. gal/litres 2.1 / 8.0
Windshield Washer Fluid quarts/litres 5.1 / 4.8
Engine Oil quarts/litres 4.5 / 4.5
Engine Data:
Dimensions:
Capacities:
