Clochner,
I’m going to go against the grain on this one.
I firmly believe that LC would, scratch that, could make a difference with 1/4 ET vs PT’s method. It really comes down to traction.
There are a number of factors that will affect your traction off the line:
- track temperature
- track prep
- tire temperature
- tire condition
- tire pressure
- Launch RPM or TQ off the line
Though I’m sure there are more I’m going to stick with the basics above for our purposes. Now going through the above list a number of these variables are, for the most part, out of your control:
- track temperature (weather dependent)
- track conditions (track dependent)
- LC launch RPM (Audi or APR dependent)
Now, the good news is that there are still variables that are of your control like:
- tire condition
- tire temperature
- tire pressure (This one is key)
Tire condition - not only refers to having good tread on your tires but also to ensure that the tread is clear of rocks, sand, dust, etc. To ensure good tire condition I check my tread levels but also I do a mini burnout (Jspazz method) each time in the staging lane before I stage. This removes rocks, gravel, etc off the tires nicely (side-note, since I’ve started to do mini burnouts I have NOT had the 1-2 shift hang-up that had been plaguing my car in the previous outings).
Tire temperature - I use a combination of hot lapping and mini burnouts (mentioned earlier) to get the tires nice and warm before I make a serious pass.
Finally, tire pressure - This one, in my mind, is going to be KEY to getting your LC to work effectively. You’re going to need to adjust pressure throughout the day for all four tires based on temperature, track conditions, and tire temperature. I’d start with a tire pressure of say 33psi fronts and 28psi rears. Do a few launches and adjust from there. You’re probably going to go down to 28psi fronts and 23-24psi rears but that’s just a guess.
I think looking at previous data regarding LC vs. non-LC is misleading. I’m not sure many B8 S4 owners are actually drag strip vets and they may not understand the importance of tire condition not to mention the macho factor (we all get trapped in on occasion) of trying to beat the guy beside you and at the same time trying to get your LC to work without overheat.
Anyway, this is just my $0.02 on the matter… Give it a try and let us know how you do… Good Luck!
