Naturally aspirated cars where exhaust manifold restrictions yield big gains, sure. This is not an na car.
Just make sure you don’t change your tune from beta to final. Or anything else. Would be nice to see a comparison of performance parts vs each other without other changes muddying the results.
With his flash loader he can compare are (stock) as well. Helps isolate the tune.
Yeah I won’t change anything I’ll do a before and after without anything else changing
And who is doin the motor pull?
I’m probably going to install the Catback right away because I’m switching to Milltek and sold my AWE and headers will follow within the next few weeks…
I’m going to drop the front subframe as much as I could on a lift and install them without removing the engine or trans. It’ll be a bitch but I’ll get it done lol.
So when are you planning to do this?
You don’t have to pull the motor.
I had mine done with one of my clutch jobs lol. It’s very little work when you do at the same time. Either way you don’t have to pull the engine if you know what your doing.
oh really? That’s good.
On the b6/7 it was assured that you’d need to pull it. B8 has a much bigger chassis so that’s great you can cut costs a bit on install.
Temp: 58 Degrees
DA: -4942013 S6 DSG 93
Mods: Unitronic Tune only0-60: 3.52s
0-100: 8.08s
60-130: (Did not register)
1/4 mile: 11.74@116.46mph2010 S4 DSG 93
Mods: GIAC Stage 2 (17psi), AWE Non-Res Exhaust, Roc Intake, DSG flash, APR CPS0-60: 4.07s
0-100: 9.24s
60-130: 11.96s
1/4 mile: 12.46@116.74mph2012 335is 6MT 93:
Mods: JB4 Map 7, Meth, Cat-less downpipes, DCI, CM Stage 4 clutch, Tial BOV, upgraded fuel pump 255.60-120: 7.7s
60-130: 10.2s2013 M3 6MT 93
Mods: ESS-VTT625 Supercharger Kit (8.5PSI), Eissenman Race Exhaust, X-pipe, HFC’s, Brembo BBK all around60-120: 7.1s
60-130: 8.6s2013 S4 6MT 93
Mods: GIAC Stage 2 BETA (14psi), Custom Heat-exchanger, AWE Resonated Exhaust, 034 HFC, Roc Intake0-60: 4.05s
0-100: 9.62s
60-130: 11.9s
1/4 mile: 12.46@114.19mph2011 S4 6MT 93
Mods: APR Stage 2 V2.2 (17psi), AWE Catback, Roc Intake, APR CPS, JHM LW Rotors60-130: 10.89s
Same S6 ran at island dragway other night…
Pump full weight 21" adv1 pss 255/30/21
It’s funny how they’re so consistent. Terrifyingly consistent.
All running 11.6-11.7 @ 118
Thats the third tuned S6/S7 time I believe
Tsiva, Isn’t that slip from sciblades? He runs Uni, doesn’t he? An APR S6 went 11.49 at 119.26 on race… posted on vendorzine…
Temp: 58 Degrees
0-100: 8.08s
0-100: 9.24s
60-130: 11.96s
0-100: 9.62s
60-130: 11.9s
Yeah, that’s my buddy chris. He’s coming to show n go Sunday to race. He’s hoping for an 11.3 as it should be freezing.
Cool… 11.3x is feasible in better conditions… Do you know is he using LC? Can you guys get some vids? Does he have a gopro? Would love to see the shifts/points via vid…
