A fellow member here is looking to sell me his JHM flashing cable, new version. Will I be able to use it and have access to the server or do I have to buy a brand new one from JHM for it to work with me?
If the member has been able to flash there TCU then you should be good. As the new server launched with the cables and TCU tunes for the S6.
The only hang up will be that you’ll need an account made for you. But you can just contact JHM and have that done.
It worked on his c6 s6 TCU and ECU. Once I receive it I’ll email v10@ and and see how I set up my account
Have there been any changes to the ECU tune since going to this new server stuff? and if I get the TCU tune do I need to reflash the ECU for any reason?
I think JHM has made a few updates to the non Cat and SAI files. But if you flash the TCU you don’t need to flash update your ECU. They have been pretty good making sure the two work together.
One of the local guys cars I service did the TCU recently. It’s a really fantastic addition if you don’t already have it.
Is there any weirdness with MY2007 cars. Does the Power Connect / new cable work to flash both engine and trans?
