So my question is simple. The hose coming off the front of the IM, is this solely for the SAI system? I ask because the rear of the IM / upper Y intake vacuum inlet goes directly to the suction jet pump for the brake assist? - my assumption
Is the vacuum port in the front even needed if you dont have the sai system on the car?! It is labeled as emissions: AUDI OEM 07-11 S6 5.2L-V10 Emission-Check Valve 058905291K
My objective is to remove un-needed vacuum systems in attempts to narrow down why my vacuum pump still running all the time while braking as if there is not enough vacuum stored in the vacuum system
From the vacuum routing there is a small secondary vacuum reservoir on the drivers side of the car under the fender and a set of bluebells vacuum resevoir on the passanger side connected by a hard line that spans the front of the engine.
Do we need the blue balls for brake assist?
I am wondering if vacuum stored in the blue balls travels through the front IM to the rear upon throttle lift and used for the brake assist, etc…
