Vag-Com Codes help // EPC ESP Limp Mode
Hi guys,
This morning after being stuck in some stop&go traffic for about 20mins, I turned off onto my street, pressed on the accelerator, and the car went into limp mode. ESP Fault message, EPC light. Your standard no power and max 40km/h. When stopped, the idle went from normal to really rough, back to normal, repeat.
Shut off the car, turned it back on. Faults persist (even when just in acc, no engine running). Tried that a few times. Then left the car off for 20 mins or so, back on, and she’s back to normal.
Now, this has happened to many people - including some of my friends, and normally it has been cured by coilpacks, though all the codes point to throttle body. I have the coilpacks in stock, and I will try them shortly. But I thought some of these codes may be curious, and I thought I would also post all this for posterity.
I made it home later in the day, although the car did beep at me for half a second at one point - just long enough for me to see “ESP Fault!” Then it disappeared and car continued as normal.
I scanned the car when I got home, and found the following. Some codes I couldn’t find on Ross-Tech - any idea? I have only a SuperVAG handheld reader.
289 ??? Anyone?
545 Angle Sensor for Throttle (G188): Implausible Signal
1056 Catalyst, Bank 1, Efficiency Below Threshold
5445 Throttle Valve Controller: Malfunction
5480 ???
5497 Throttle Actuator (J338): Adaptation Not Started
5715 Please Check Memory of ABS Controller
8454 ???
Thanks guys,
P
