VAGCom Errors on '09 S6 - Free advice appreciated
I was driving my car fast in “S” the other night to dry it off after a wash when the engine light began to flash on the dash. I slowed down and put it into “D” then the engine light stopped flashing and I have not seen the engine light flash since then. I scanned it today and got the following errors. Any experts here who can help me understand what is going on?
Another issue I have is bad gas mileage, even on the highway. After new plugs and filters it still averages only 15-16 mpg. This may be common with a V10 but I thought that it would be better on long HW trips. Do any of these error codes point to anything?
Address 01: Engine (BXA) Labels: Redir Fail!
Part No SW: 4F1 910 562 A HW: 4F1 907 552 B
Component: 5.2L V10/4V FSI ª0010
Revision: 5HH03— Serial number:
Coding: 01050009190F0160
Shop #: WSC 02256 785 00200
VCID: 23450795E219603953D-8076
1 Fault Found:
P1923 - 008 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 100252 km
Time Indication: 0
Date: 2015.05.16
Time: 07:49:08
         Freeze Frame:
                RPM: 0 /min
                Load: 0.0 %
                Speed: 0.0 km/h
                Temperature: 42.0°C
                Temperature: 42.0°C
                Absolute Pres.: 990.0 mbar
                Voltage: 11.303 V
Readiness: 0000 0000
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 B HW: 4F0 905 852 E
Component: FBSAUDIC6 ELV H05 0100
Revision: 00H05000 Serial number: 10602501248037
Coding: 0000007
Shop #: WSC 02323 785 00200
VCID: 2541198DEC2D9E093D9-8070
Subsystem 1 - Part No: 4F0 910 132 L
Component: FBSAUDIC6 EZS H03 0020
Subsystem 2 - Part No: 4F0 910 335 B
Component: FBSAUDIC6 KSG H03 0020
1 Fault Found:
00956 - Key 2
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00110010
Fault Priority: 3
Fault Frequency: 2
Reset counter: 153
Mileage: 99655 km
Time Indication: 0
Date: 2015.05.07
Time: 17:50:25
2 Faults Found:
P0300 - 001 - - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 100136 km
Time Indication: 0
Date: 2015.05.14
Time: 20:56:32
         Freeze Frame:
                RPM: 5294 /min
                Load: 92.5 %
                Speed: 111.0 km/h
                Temperature: 82.0°C
                Temperature: 30.0°C
                Voltage: 12.954 V
000770 - Cylinder 2
P0302 - 001 - Misfire Detected - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 100136 km
Time Indication: 0
Date: 2015.05.14
Time: 20:56:32
         Freeze Frame:
                RPM: 5294 /min
                Load: 92.5 %
                Speed: 111.0 km/h
                Temperature: 82.0°C
                Temperature: 30.0°C
                Voltage: 12.954 V
Address 3C: Lane Change Labels: None
Part No SW: 4L0 910 566 D HW: 4L0 907 566 B
Component: J0769_SWA_MasterH01 0010
Revision: 00H01000 Serial number: 6PZ 009 014-15
Coding: 0000002
Shop #: WSC 02325 785 00200
VCID: 2F6DFBA5BED1D459C75-807A
Subsystem 1 - Part No: 4L0 910 568 D
Component: J0770_SWA_Slave_H01 0010
Subsystem 2 - Serial number: 6PZ 009 014-35
Subsystem 3 - Serial number: 5F10.01.0900H010003CN10285ÿ
Subsystem 4 - Serial number: N10285ÿ
1 Fault Found:
02850 - Control Module 2 for Lane Change Assistance (J770)
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 3
Fault Frequency: 1
Reset counter: 8
Mileage: 96140 km
Time Indication: 0
Date: 2015.04.02
Time: 20:42:48
End-------------------------(Elapsed Time: 03:35)--------------------------
