FYI… if anyone upgrades to VCDS 11.11 all the fields changed for the B8… Old on the left and new on the right… Caught me off guard at the track but I think I have all the critical ones x-refed… If you are serious about your car you should be logging it when you drag race, road race, or just beat on it… I digress…
Also, the new version allows for 12 fields to be logged in turbo with grouping as I had some issues with the last version with it not working with 8+ fields… maybe it was me?
Here you go…
VCDS Description VCDS 11.11 Block #
21 Throttle Position 13
24 Accelerator Position 16
33 Long Term Fuel Trim Bank 1 23
34 Long Term Fuel Trim Bank 2 24
35 Engine Speed 25
128 Ambient Pressure 39
292 Timing Retard Cyl 1 216
293 Timing Retard Cyl 2 217
294 Timing Retard Cyl 3 218
295 Timing Retard Cyl 4 219
296 Timing Retard Cyl 5 220
297 Timing Retard Cyl 6 221
298 Ignition Angle 222
421 Mass Air Flow 345
436 Boost Pressure(Absolute) 360
632 Intake Air Temperature 556
700 Boost specified 623
702 Boost Pressure Valve Angle 625
Hope this helps… Let me know if I am wrong on any or there are ?'s… later Ron
