Replacing valve cover gaskets as my spark plug wells had quite a bit of oil in them. I was able to remove my driver side valve cover, but I have 2 questions I’m hoping I could give some insight on as I move forward:
1.) As I finish cleaning up the mating surfaces - do I need to use any kind of sealant when I install the new gasket? As much as I’ve been researching this I can’t seem to find any definitive answer. I did end up buying Reinzosil from JHM so if it is advised to use this or something like it can someone point me in the right direction on how/where to apply it?
2.) My passenger side valve cover of course has that rear lower bolt rounded off. I have a wonderful tiny ratchet the will fit in that tight space but since the torx is stripped I’m struggling with options on how to extract. Most other options I would normally use seem to be futile due to the limited amount of access back there. I’m considering using a sharp chisel and hammer to try and snap off the bolt head - how terrible of an idea is this? And does anyone have any suggestions on other things I can try?
