I’m the proud owner of a 2006 V10 S6. I’ve had the car for around 2 months and I got it for a good price. I think I’ve found out why now. After getting the car I took her for a complimentary health check with Audi. They found an oil leak that wasn’t apparent when looking at the underside of the car. I took it to an Audi specialist who couldn’t find the source of it. He left the engine running for an hour and it didn’t drip. He said ‘next time you bring it we’ll have a proper look.’ I’d have hoped he’d had a proper look the first time really.
I then took it to another garage who pretty much straight away identified the leak as being the front crankshaft seal, and likely the rear seal too. It is also probably leaking from the bottom pan (I forget it’s actual name). The quotes for the work are very realistic. I know there’s a lot involved; removing the transmission, removing the front bumper etc. Could be worse though!
I’m a bit of a car DIY’er, but the V10 and Audi in general are beyond me. I still like to understand what’s going on. After reading through this forum I’m suspecting that the crankcase breather system may not be working leading to seal fails on the front and the back. I don’t want to replace the seals without identifying why they’re leaking. I’m hoping if I’m right I should be able to replace the breather oil separator and check for blockages and the seals won’t fail again.
I’d be interested to hear if I’m on the right lines or if there’s something else I should be thinking about. I don’t have any misfires, the car runs and pulls smooth, and the oil level doesn’t move much (probably because he overfilled it so much before he sold it to me knowing it had a leak!). She’s a fast little bugger too with no apparent flat spots so I think the engine is fine.
Once I’ve sorted the leaks I’ll be taking the car for a carbon clean and tune. Then I’ll be looking forward to trouble free motoring…
